Cisco Catalyst Compact 3560C-8PC-S 8-port Managed Switch
Quicklinx: 8KN7WS00 Mfr#: WS-C3560C-8PC-S
The Cisco Catalyst 3560-C series compact switch is a small form-factor Gigabit Ethernet and Fast Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, branch office, classroom, cruise ship, and other wiring-constrained environments.
  • Robust security
    Equipped with Kerberos, RADIUS, Secure Shell (SSH), and TACACS+ authentication methods, this switch ensures secure network access and management, safeguarding against unauthorized access.
  • Comprehensive networking capability
    Supports a wide range of IEEE standards including 802.1D/Q/ab/ae and more, alongside features like ARP support, Access Control List (ACL) support, and Quality of Service (QoS), making it versatile for various networking needs.
  • Efficient power management
    With a PoE budget of 124 W and support for PoE+, the switch efficiently powers connected devices such as VoIP phones and wireless access points, reducing cable clutter and power outlet demand.
  • Flexible deployment options
    The form factor allows for desktop, rack-mountable, or wall-mountable setups, offering flexibility in deployment according to space and usage requirements.
  • High performance and reliability
    Features like fanless design for silent operation, jumbo frame support up to 9018 bytes for improved data transfer, and a forwarding performance of 10 Gbps to handle data-intensive tasks efficiently.
Cisco Catalyst Compact 3560C-8PC-S - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
124 W
Performance
Forwarding performance (64-byte packet size): 4.2 Mpps , Forwarding performance: 10 Gbps
Virtual interfaces (VLANs): 1005
Jumbo Frame Support
9018 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, OSPFv2
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DAI, UDLD, fanless, DHCP relay, LACP, RSPAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3at
26.9 cm x 21.3 cm x 4.44 cm
1.86 kg
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
124 W
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
Status Indicators
Port status, system, link/activity
2 x 1000Base-T RJ-45 , 8 x 100Base-TX RJ-45 PoE+ , 1 x management (mini-USB) Type B , 1 x management (RS-232) RJ-45 , 2 x SFP uplink , 1 x USB Type A
Internal power supply
MTBF
373,635 hour(s)
GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
Software Included
Cisco IOS IP Base
26.9 cm
21.3 cm
4.44 cm
1.86 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
8KN7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £13.84
