The Cisco Catalyst 3560-C series compact switch is a small form-factor Gigabit Ethernet and Fast Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, branch office, classroom, cruise ship, and other wiring-constrained environments.
Robust security
Equipped with Kerberos, RADIUS, Secure Shell (SSH), and TACACS+ authentication methods, this switch ensures secure network access and management, safeguarding against unauthorized access. -
Comprehensive networking capability
Supports a wide range of IEEE standards including 802.1D/Q/ab/ae and more, alongside features like ARP support, Access Control List (ACL) support, and Quality of Service (QoS), making it versatile for various networking needs. -
Efficient power management
With a PoE budget of 124 W and support for PoE+, the switch efficiently powers connected devices such as VoIP phones and wireless access points, reducing cable clutter and power outlet demand. -
Flexible deployment options
The form factor allows for desktop, rack-mountable, or wall-mountable setups, offering flexibility in deployment according to space and usage requirements. -
High performance and reliability
Features like fanless design for silent operation, jumbo frame support up to 9018 bytes for improved data transfer, and a forwarding performance of 10 Gbps to handle data-intensive tasks efficiently.
- Cisco Catalyst Compact 3560C-8PC-S - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE+) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 124 W
- Performance
- Forwarding performance (64-byte packet size): 4.2 Mpps , Forwarding performance: 10 Gbps
- Capacity
- Virtual interfaces (VLANs): 1005
- Jumbo Frame Support
- 9018 bytes
- Routing Protocol
- OSPF, RIP-1, RIP-2, OSPFv2
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DAI, UDLD, fanless, DHCP relay, LACP, RSPAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 26.9 cm x 21.3 cm x 4.44 cm
- 1.86 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE+
- PoE Budget
- 124 W
- Performance
- Capacity
- 9018 bytes
- Routing Protocol
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 64 MB
- Status Indicators
- Port status, system, link/activity
- 2 x 1000Base-T RJ-45 , 8 x 100Base-TX RJ-45 PoE+ , 1 x management (mini-USB) Type B , 1 x management (RS-232) RJ-45 , 2 x SFP uplink , 1 x USB Type A
- Power Device
- Internal power supply
- Voltage Required
- MTBF
- 373,635 hour(s)
- GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
- Software Included
- Cisco IOS IP Base
- 26.9 cm
- 21.3 cm
- 4.44 cm
- 1.86 kg
- Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
- -5 °C
- 40 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.84 |
