Cisco Catalyst 9300L 48-port PoE+, 4X10G uplinks,Network Essentials
Quicklinx: G2R9WS00 Mfr#: C9300L-48P-4X-E
Type: Gigabit Ethernet
Ports: 48
POE: PoE+
11 In Stock
£4,768.27 ex VAT
£5,721.92 inc VAT
The Cisco Catalyst 9300 Series switches are Cisco's lead stackable enterprise switching platform built for security, IoT, mobility, and cloud. They are the next generation of the industry's most widely deployed switching platform. Catalyst 9300 Series switches form the foundational building block for Software-Defined Access (SD-Access), Cisco's lead enterprise architecture. At up to 480 Gbps, they are the industry's highest-density stacking bandwidth solution with the most flexible uplink architecture. The Catalyst 9300 Series is the first optimized platform for high-density Wi-Fi 6 and 802.11ac Wave2. It sets new maximums for network scale. These switches are also ready for the future, with an x86 CPU architecture and more memory, enabling them to host containers and run third-party applications and scripts natively within the switch.
The Catalyst 9300 Series is designed for Cisco StackWise technology, providing flexible deployment with support for nonstop forwarding with Stateful Switchover (NSF/SSO), for the most resilient architecture in a stackable (sub-50-ms) solution. The highly resilient and efficient power architecture features Cisco StackPower, which delivers high-density Cisco Universal Power over Ethernet (Cisco UPOE) and Power over Ethernet Plus (PoE+) ports. The switches are based on the Cisco Unified Access Data Plane 2.0 (UADP) 2.0 architecture which not only protects your investment but also allows a larger scale and higher throughput. A modern operating system, Cisco IOS XE with programmability offers advanced security capabilities and Internet of Things (IoT) convergence.
  • BUILT-IN RESILIENCY
    High-end fixed switching for Software-Defined Access, App hosting, high availability, assurance, and smart buildings
  • HIGH PERFORMANCE AND SCALABILITY
    Support for high-density 10G and 40G uplinks with up to 480 Gbps of stacking bandwidth for robust performance and network expansion.
  • ADVANCED SECURITY
    Features like Encrypted Traffic Analytics (ETA) and Cisco TrustSec provide comprehensive security, including Network Access Control (NAC) capabilities.
  • UP TO 1TB OF STACKING BANDWIDTH
    With Stackwise-1T, Catalyst 9300 switches are the industry's highest-density stacking bandwidth solution with the most flexible uplink architecture.
  • CLOUD MANAGEMENT AND MONITORING
    Cloud management and monitoring provides the ability to manage or view Catalyst 9300 switch statistics, configuration, and troubleshooting capabilities in Meraki dashboard.
Cisco Catalyst 9300L - Network Essentials - switch - 48 ports - rack-mountable
Switch - 48 ports - L3 - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+ (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
505 W
Performance
Switching capacity with stacking: 496 Gbps , Switching capacity: 176 Gbps , Forwarding rate: 130.95 Mpps , Forwarding rate with stacking: 369.05 Mpps
IPv4 routes: 32000 , IPv6 routes: 16000 , Multicast scale: 8000 , QoS scale entries: 5120 , ACL scale entries: 5120 , Routed ports: 416 , VLANs supported: 4094 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
QoS, Cisco StackWise Technology, Rapid PVST+, SRR, PXE support, RSPAN, NetFlow, Energy Efficient Ethernet, MIB, CoS, FNF, 802.1x authentication, 16MB packet buffer, DSCP support, MACsec support, CoPP, SPAN, EEM, PIM, FHS, PVLAN support, CIR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
Power Redundancy
Optional
44.5 cm x 4.4 cm x 40.9 cm
7.03 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
505 W
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
RAM
8 GB
Flash Memory
16 GB
48 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP+ uplink
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
715 watt
MTBF
309,020 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
44.5 cm
4.4 cm
40.9 cm
7.03 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
G2R9 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.70
G2R9 Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
G2R9 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £19.94
Ports: 48
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
