The Cisco Catalyst 9300 Series switches are Cisco's lead stackable enterprise switching platform built for security, IoT, mobility, and cloud. They are the next generation of the industry's most widely deployed switching platform. Catalyst 9300 Series switches form the foundational building block for Software-Defined Access (SD-Access), Cisco's lead enterprise architecture. At up to 480 Gbps, they are the industry's highest-density stacking bandwidth solution with the most flexible uplink architecture. The Catalyst 9300 Series is the first optimized platform for high-density Wi-Fi 6 and 802.11ac Wave2. It sets new maximums for network scale. These switches are also ready for the future, with an x86 CPU architecture and more memory, enabling them to host containers and run third-party applications and scripts natively within the switch.
The Catalyst 9300 Series is designed for Cisco StackWise technology, providing flexible deployment with support for nonstop forwarding with Stateful Switchover (NSF/SSO), for the most resilient architecture in a stackable (sub-50-ms) solution. The highly resilient and efficient power architecture features Cisco StackPower, which delivers high-density Cisco Universal Power over Ethernet (Cisco UPOE) and Power over Ethernet Plus (PoE+) ports. The switches are based on the Cisco Unified Access Data Plane 2.0 (UADP) 2.0 architecture which not only protects your investment but also allows a larger scale and higher throughput. A modern operating system, Cisco IOS XE with programmability offers advanced security capabilities and Internet of Things (IoT) convergence.
BUILT-IN RESILIENCY
High-end fixed switching for Software-Defined Access, App hosting, high availability, assurance, and smart buildings -
HIGH PERFORMANCE AND SCALABILITY
Support for high-density 10G and 40G uplinks with up to 480 Gbps of stacking bandwidth for robust performance and network expansion. -
ADVANCED SECURITY
Features like Encrypted Traffic Analytics (ETA) and Cisco TrustSec provide comprehensive security, including Network Access Control (NAC) capabilities. -
UP TO 1TB OF STACKING BANDWIDTH
With Stackwise-1T, Catalyst 9300 switches are the industry's highest-density stacking bandwidth solution with the most flexible uplink architecture. -
CLOUD MANAGEMENT AND MONITORING
Cloud management and monitoring provides the ability to manage or view Catalyst 9300 switch statistics, configuration, and troubleshooting capabilities in Meraki dashboard.
 - Cisco Catalyst 9300L - Network Essentials - switch - 24 ports - Managed - rack-mountable
 - Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000 (PoE+) + 4 x Gigabit SFP (uplink)
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 505 W
- Performance
 - Switching capacity: 128 Gbps , Switching capacity with stacking: 448 Gbps , Forwarding rate: 95.23 Mpps , Forwarding rate with stacking: 333.33 Mpps
- Capacity
 - IPv4 routes: 32000 , IPv6 routes: 16000 , Multicast scale: 8000 , QoS scale entries: 5120 , ACL scale entries: 5120 , VLANs supported: 4094 , Switched virtual interfaces (SVIs): 1000
- MAC Address Table Size
 - 32000 entries
- Jumbo Frame Support
 - 9198 bytes
- Routing Protocol
 - OSPF, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
- Remote Management Protocol
 - SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF, gRPC, IPv4, IPv6, YANG
 - ACL support, QoS, Rapid PVST+, SRR, PXE support, Energy Efficient Ethernet, CoS, FNF, 802.1x authentication, DSCP support, MACsec support, CoPP, Blue Beacon LED, ZTP, secure boot, PIM, FHS, PVLAN support, CIR, Cisco Trust Anchor module, Cisco UADP 2.0, Cisco StackWise-320 technology
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 1588v2, IEEE 802.1BA, Wi-Fi CERTIFIED 6
- Power
 - AC 120/230 V (50 - 60 Hz)
- Power Redundancy
 - Optional
 - 44.5 cm x 4.4 cm x 48.8 cm
 - 6.81 kg
 - Limited lifetime warranty
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 505 W
- Performance
- Capacity
 - 32000 entries
 - 9198 bytes
- Routing Protocol
- Encryption Algorithm
 - 128-bit AES, 256-bit AES
- RAM
 - 8 GB
- Flash Memory
 - 16 GB
- Status Indicators
 - Status
 - 24 x 1000Base-T RJ-45 505 W , 4 x 10GBase-X SFP+ uplink , 1 x network stack device , 1 x management (LAN) RJ-45 , 1 x console , 1 x USB 2.0
- Power Device
 - Internal power supply - hot-plug
- Installed Qty
 - 1
- Max Supported Qty
 - 2
- Power Redundancy
 - Optional
- Power Provided
 - 715 Watt
- Voltage Required
- MTBF
 - 340,710 hours
 - CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
 - 44.5 cm
 - 4.4 cm
 - 48.8 cm
 - 6.81 kg
 - Limited warranty - replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
 - -5 °C
 - 45 °C
 - 5 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
                        Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £81.10 |
                        Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.99 |
