The Catalyst 9300 series is an advanced stackable switching platform. These network switches are built for security, IoT, and the cloud.
BUILT-IN RESILIENCY
High-end fixed switching for Software-Defined Access, App hosting, high availability, assurance, and smart buildings -
HIGH PERFORMANCE AND SCALABILITY
Support for high-density 10G and 40G uplinks with up to 480 Gbps of stacking bandwidth for robust performance and network expansion. -
ADVANCED SECURITY
Features like Encrypted Traffic Analytics (ETA) and Cisco TrustSec provide comprehensive security, including Network Access Control (NAC) capabilities. -
UP TO 1TB OF STACKING BANDWIDTH
With Stackwise-1T, Catalyst 9300 switches are the industry's highest-density stacking bandwidth solution with the most flexible uplink architecture. -
CLOUD MANAGEMENT AND MONITORING
Cloud management and monitoring provides the ability to manage or view Catalyst 9300 switch statistics, configuration, and troubleshooting capabilities in Meraki dashboard.
 - Cisco Catalyst 9300 - Network Essentials - switch - 48 ports - Managed - rack-mountable
 - Switch - 48 ports - L3 - Managed - stackable
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 48 x 10/100/1000
- Performance
 - Switching capacity: 128 Gbps , Stacking bandwidth: 480 Gbps , Forwarding rate: 190.48 Mpps
- Capacity
 - IPv4 routing table entries: 32000 , IPv6 routing table entries: 16000 , Flexible NetFlow entries: 64000 , VLAN IDs: 4000 , Switched virtual interfaces (SVIs): 2000
- MAC Address Table Size
 - 32000 entries
- Jumbo Frame Support
 - 9198 bytes
- Routing Protocol
 - OSPF, IS-IS, RIP-1, RIP-2, BGP, EIGRP, HSRP, IGMP, VRRP, PIM-SM, OSPFv3, PIM-SSM, MSDP, policy-based routing (PBR), RIPng
- Remote Management Protocol
 - SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
 - DHCP support, trunking, Syslog support, full duplex mode, SSO, CBWFQ, WRED, STP support, ACL support, QoS, NSR, RSPAN, MIB, Cisco StackWise-480 technology, Cisco StackPower technology, FNF, MSDP, 802.1x authentication, 16MB packet buffer, FTP client, MACsec support, 3 fans, CoPP, VXLAN, AVC, SSM, integrated Wireshark, VLAN Double Tagging (Q-in-Q), EoMPLS, H-VPLS, Private VLAN, L3VPN support, ERSPAN, SGT caching, SGACL, ITSM integration, third-party IPAM integration
 - IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
 - AC 120/230 V (50 - 60 Hz)
- Power Redundancy
 - Optional
 - 44.4 cm x 48.8 cm x 4.3 cm
 - 7.86 kg
- System Requirements
 - Cisco IOS Universal
 - Limited lifetime warranty
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 48 x 10/100/1000
- Performance
- Capacity
 - 32000 entries
 - 9198 bytes
- Routing Protocol
- Encryption Algorithm
 - 128-bit AES
- RAM
 - 8 GB
- Flash Memory
 - 16 GB
- Status Indicators
 - Status
 - 48 x Gigabit LAN SFP uplink , 1 x USB 2.0
- Expansion Slots
 - 1 (total) / 1 (free) x Expansion Slot
- Power Device
 - Internal power supply - hot-plug
- Installed Qty
 - 1
- Max Supported Qty
 - 2
- Power Redundancy
 - Optional
- Power Provided
 - 715 Watt
- Voltage Required
- MTBF
 - 281,920 hours
 - CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, EN 55022 Class A, FCC CFR47 Part 15 A, EN 300 386, TVCN 7317, VCCI V-3/2009 Class A, CAN/CSA-C22.2 No. 60950-1
- OS Required
 - 44.4 cm
 - 48.8 cm
 - 4.3 cm
 - 7.86 kg
 - Limited warranty - replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
 - -5 °C
 - 45 °C
 - 5 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
                        Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £81.10 |
                        Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.99 |
                        Cisco 1m Type 1 Stacking Cable | In Stock | £238.49 |
                        Cisco StackWise 480 Stacking Cable 50cm | In Stock | £108.40 |
                        Cisco StackPower Power Cable 30cm | In Stock | £108.40 |
                        Cisco Catalyst 9300 8 X 10GE | In Stock | £1,131.50 |
