The Catalyst 9300 series is an advanced stackable switching platform. These network switches are built for security, IoT, and the cloud.
Cloud ready
Simplify, secure, and transform your cloud environment. Cisco delivers a digital-ready approach that starts at the edge and extends to where applications reside. -
Optimized for mobility
Catalyst 9300 series access switches give you smart, simple, and highly secure unified access.
- Cisco Catalyst 9300 - Network Essentials - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 445 W
- Performance
- Switching capacity: 128 Gbps , Stacking bandwidth: 480 Gbps , Forwarding rate: 154.76 Mpps
- Capacity
- IPv4 routing table entries: 32000 , IPv6 routing table entries: 16000 , Flexible NetFlow entries: 64000 , VLAN IDs: 4000 , Switched virtual interfaces (SVIs): 2000
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 9198 bytes
- Routing Protocol
- OSPF, IS-IS, RIP-1, RIP-2, IGMP, VRRP, PIM-SM, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
- Trunking, full duplex mode, WRED, STP support, ACL support, QoS, RSPAN, MIB, Cisco StackWise-480 technology, Cisco StackPower technology, FNF, 802.1x authentication, 16MB packet buffer, FTP client, 3 fans, CoPP, SSM, integrated Wireshark, VLAN Double Tagging (Q-in-Q), Private VLAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
- Power
- AC 120/230 V (50 - 60 Hz)
- Power Redundancy
- Optional
- 44.5 cm x 44.5 cm x 4.4 cm
- 7.4 kg
- System Requirements
- Cisco IOS Universal
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 445 W
- Performance
- Capacity
- 32000 entries
- 9198 bytes
- Routing Protocol
- Encryption Algorithm
- 128-bit AES
- RAM
- 8 GB
- Flash Memory
- 16 GB
- Status Indicators
- Status
- 48 x 1000Base-T RJ-45 PoE+ , 1 x USB 2.0
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Provided
- 715 Watt
- Voltage Required
- MTBF
- 299,000 hours
- CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, EN 55022 Class A, FCC CFR47 Part 15 A, EN 300 386, TVCN 7317, VCCI V-3/2009 Class A, CAN/CSA-C22.2 No. 60950-1
- OS Required
- 44.5 cm
- 44.5 cm
- 4.4 cm
- 7.4 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
- -5 °C
- 45 °C
- 5 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco 10GBASE-SR SFP Module | In Stock | £362.75 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £80.94 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £38.19 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £20.67 |
Cisco 1m Type 1 Stacking Cable | In Stock | £230.09 |
Cisco StackWise 480 Stacking Cable 3m for Catalyst 38 | In Stock | £223.33 |
Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC | In Stock | £1,478.84 |
Cisco StackWise 480 Stacking Cable 50cm | In Stock | £108.22 |
Cisco StackPower Power Cable 30cm | In Stock | £104.60 |
Cisco Catalyst 9300 8 X 10GE | In Stock | £1,101.22 |
