Cisco Catalyst 9300 24-port mGig and UPOE, Network Essential
Quicklinx: G2QNWS00 Mfr#: C9300-24UX-E
Type: 10 Gigabit Ethernet
Ports: 24
Managed: Yes
POE: UPOE
£6,528.16 ex VAT
£7,833.79 inc VAT
  • BUILT-IN RESILIENCY
    High-end fixed switching for Software-Defined Access, App hosting, high availability, assurance, and smart buildings
  • HIGH PERFORMANCE AND SCALABILITY
    Support for high-density 10G and 40G uplinks with up to 480 Gbps of stacking bandwidth for robust performance and network expansion.
  • ADVANCED SECURITY
    Features like Encrypted Traffic Analytics (ETA) and Cisco TrustSec provide comprehensive security, including Network Access Control (NAC) capabilities.
  • UP TO 1TB OF STACKING BANDWIDTH
    With Stackwise-1T, Catalyst 9300 switches are the industry's highest-density stacking bandwidth solution with the most flexible uplink architecture.
  • CLOUD MANAGEMENT AND MONITORING
    Cloud management and monitoring provides the ability to manage or view Catalyst 9300 switch statistics, configuration, and troubleshooting capabilities in Meraki dashboard.
Cisco Catalyst 9300 - Network Essentials - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 100/1000/2500/5000/10000 (UPOE)
Power Over Ethernet (PoE)
UPOE
PoE Budget
560 W
Performance
Stacking bandwidth: 480 Gbps , Forwarding rate: 400 Mpps
IPv4 routing table entries: 32000 , IPv6 routing table entries: 16000 , Flexible NetFlow entries: 64000 , VLAN IDs: 4000 , Switched virtual interfaces (SVIs): 2000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, IS-IS, RIP-1, RIP-2, IGMP, VRRP, PIM-SM, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
Trunking, full duplex mode, WRED, STP support, ACL support, QoS, RSPAN, MIB, Cisco StackWise-480 technology, Cisco StackPower technology, FNF, 802.1x authentication, 16MB packet buffer, FTP client, 3 fans, CoPP, SSM, integrated Wireshark, VLAN Double Tagging (Q-in-Q), Private VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
AC 120/230 V (50 - 60 Hz)
Power Redundancy
Optional
47 cm x 44.5 cm x 4.4 cm
8.25 kg
Cisco IOS Universal
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
UPOE
PoE Budget
560 W
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Encryption Algorithm
128-bit AES
RAM
8 GB
Flash Memory
16 GB
Status Indicators
Status
48 x 10GBase-T RJ-45 UPOE , 1 x USB 2.0
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
1100 Watt
MTBF
214,760 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, EN 55022 Class A, FCC CFR47 Part 15 A, EN 300 386, TVCN 7317, VCCI V-3/2009 Class A, CAN/CSA-C22.2 No. 60950-1
Cisco IOS Universal
47 cm
44.5 cm
4.4 cm
8.25 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
5 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
G2QN Cisco 10GBASE-SR SFP Module In Stock £388.18
G2QN Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.80
G2QN Cisco Power Cable for Catalyst 3850-24 In Stock £40.83
G2QN Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £21.53
G2QN Cisco 1m Type 1 Stacking Cable In Stock £237.56
G2QN Cisco StackWise 480 Stacking Cable 3m for Catalyst 38 In Stock £230.60
G2QN Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC In Stock £1,527.83
G2QN Cisco StackWise 480 Stacking Cable 50cm In Stock £108.07
G2QN Cisco StackPower Power Cable 30cm In Stock £108.00
Ports: 24
Managed: Yes
POE: UPOE
Brand: Cisco
Price Range Ex VAT: £1500+
