Cisco Catalyst 9200L 48-port PoE+ 4x10G switch Network Essentials
Quicklinx: G2Q2WS00 Mfr#: C9200L-48P-4X-E
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
More than 50 In Stock
£2,841.69 ex VAT
£3,410.02 inc VAT
The Cisco Catalyst 9200 Series switch can help customers simplify complexity, optimize IT, and reduce operational costs by leveraging intelligence, automation and human expertise. This switch provides security features that protect the integrity of the hardware as well as the software and all data that flows through the switch. It provides resiliency that keeps your business up and running seamlessly. The C9200L-48P-4X-E model has 48 ports 1G PoE+ with 4x 10G SFP+ fixed uplinks. Licensing is required.
  • CONFIGURATION
    48 x 10/100/1000M Ethernet with PoE+, 4 x 10G SFP+ uplinks, 740W total PoE budget
  • IT SIMPLIFIED
    Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation
  • SECURE
    Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch
  • ALWAYS-ON
    Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies, redundant fans, 80 Gbps backplane stacking, and layer 3 support
  • MANAGEMENT
    Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
Cisco Catalyst 9200L - Network Essentials - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
Performance
Stacking bandwidth: 80 Gbps , Switching capacity: 176 Gbps , Forwarding rate: 261.9 Mpps
Virtual networks: 1 , MAC addresses: 16000 , IPv4 routes: 11000 , IPv4 routing table entries: 3000 , IPv6 routing table entries: 1500 , Multicast scale: 1000 , ACL scale entries: 1500 , FNF entries: 16000 , Switched virtual interfaces (SVIs): 512 , Queues per port (egress): 8
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP, VRRP, policy-based routing (PBR), MSTP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, NETCONF, RESTCONF
EIGRP Stub Routing, Rapid PVST+, SRR, RSPAN, CoS, FNF, DSCP support, MACsec support, 6MB packet buffer, CoPP, SSM, Blue Beacon LED, EEE, SPAN, EEM, PIM, FHS, PVLAN support, Superior QoS, CIR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3bz
AC 100-240 V - power supply not installed
44.5 cm x 4.4 cm x 28.8 cm
5.5 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
Jumbo Frame Support
9198 bytes
Routing Protocol
RAM
2 GB
Flash Memory
4 GB
Built-in Devices
RFID tag
48 x 1000Base-T RJ-45 PoE+ , 4 x 10GBase-X SFP+
Internal power supply (not installed)
Max Supported Qty
2
AC 100-240 V
MTBF
346,270 hours
Plug and Play, CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, RoHS, CNS 13438, EN 55022 Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317
44.5 cm
4.4 cm
28.8 cm
5.5 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
G2Q2 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.70
G2Q2 Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
G2Q2 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £21.29
Ports: 48
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
