Cisco Catalyst 9200L - Network Essentials - switch - L3 - 48 x 10/
Quicklinx: FX94WS00 Mfr#: C9200L-48T-4G-E
Type: Gigabit Ethernet
Ports: 48
£1,197.32 ex VAT
£1,436.78 inc VAT
The Cisco Catalyst 9200 Series switch can help customers simplify complexity, optimize IT, and reduce operational costs by leveraging intelligence, automation and human expertise. This switch provides security features that protect the integrity of the hardware as well as the software and all data that flows through the switch. It provides resiliency that keeps your business up and running seamlessly. The C9200L-48T-4G-E model has 48 ports 1G data with 4x 1G SFP fixed uplinks. Licensing is required.
  • CONFIGURATION
    48 x 10/100/1000M Ethernet, 4 x 1G SFP uplinks
  • IT SIMPLIFIED
    Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation
  • SECURE
    Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch
  • ALWAYS-ON
    Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies, redundant fans, 80 Gbps backplane stacking, and layer 3 support
  • MANAGEMENT
    Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
Cisco Catalyst 9200L - Network Essentials - switch - 48 ports - rack-mountable
Switch - 48 ports - L3 - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x Gigabit SFP (uplink)
Performance
Stacking bandwidth: 80 Gbps , Switching capacity: 104 Gbps , Forwarding rate: 154.76 Mpps
Virtual networks: 1 , IPv4 routes: 11000 , IPv4 routing table entries: 3000 , IPv6 routing table entries: 1500 , Multicast scale: 1000 , ACL scale entries: 1500 , FNF entries: 16000 , VLANs supported: 1024 , Switched virtual interfaces (SVIs): 512 , QoS hardware queues per port: 8
MAC Address Table Size
16000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
QoS, Cisco StackWise Technology, Rapid PVST+, SRR, PXE support, RSPAN, NetFlow, Energy Efficient Ethernet, MIB, CoS, FNF, 802.1x authentication, DSCP support, MACsec support, 6MB packet buffer, CoPP, SPAN, EEM, PIM, FHS, PVLAN support, CIR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
AC 100-240 V (50 - 60 Hz)
Power Redundancy
Optional
44.5 cm x 4.4 cm x 28.8 cm
4.35 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
RAM
2 GB
Flash Memory
4 GB
48 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP uplink , 1 x network stack device , 1 x management (LAN) RJ-45 , 1 x console RJ-45
Max Supported Qty
2
Power Redundancy
Optional
MTBF
508,700 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
44.5 cm
4.4 cm
28.8 cm
4.35 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
FX94 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £81.10
FX94 Cisco Power Cable for Catalyst 3850-24 In Stock £40.99
FX94 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.37
Ports: 48
Brand: Cisco
Price Range Ex VAT: £1000 - £1500
