Cisco Catalyst 9200 48-port PoE+ switch, Network Essentials
Quicklinx: G2PHWS00 Mfr#: C9200-48P-E
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£2,585.60 ex VAT
£3,102.72 inc VAT
The Catalyst 9200 series delivers the superior features. It's highly secure and always on, and it provides IT simplicity, resulting in a great experience every time.
  • CONFIGURATION
    48 x 10/100/1000M Ethernet with PoE+, 740W total PoE budget
  • IT SIMPLIFIED
    Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation
  • SECURE
    Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch
  • ALWAYS-ON
    Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies and fans, modular uplinks, 160 Gbps backplane stacking and layer 3 support
  • MANAGEMENT
    Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
Cisco Catalyst 9200 - Essential Edition - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - smart - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Wireless bandwidth: up to 48 Gbps , Switching capacity: 176 Gbps , Forwarding rate: 261.9 Mpps
Virtual networks: 4 , MAC addresses: 32000 , IPv4 routes: 14000 , Indirect IPv4 routes: 4000 , Direct IPv4 routes: 10000 , IPv4 routing table entries: 4000 , IPv6 routing table entries: 2000 , Multicast scale: 1000 , ACL scale entries: 16000 , Packet buffer size: 6 MB , Flexible NetFlow entries: 16000 , VLAN IDs: 1000
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP, IS-IS, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
Remote Management Protocol
NETCONF, RESTCONF
QoS, RSPAN, FNF, MACsec support, CoPP, Sampled NetFlow, SPAN, EEM, FHS, DNA support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3bz
AC 100-240 V
Power Redundancy
Optional
44.5 cm x 4.4 cm x 35 cm
5.5 kg
Cisco IOS XE 16.9.2 or later
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
Jumbo Frame Support
9198 bytes
Routing Protocol
NETCONF, RESTCONF
RAM
4 GB
Flash Memory
4 GB
48 x 1000Base-T RJ-45 PoE+ - 30 W
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
1000 Watt
AC 100-240 V
MTBF
375,570 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
44.5 cm
4.4 cm
35 cm
5.5 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
-5 °C
45 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
G2PH Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £81.96
G2PH Cisco Power Cable for Catalyst 3850-24 In Stock £41.43
G2PH Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.37
Ports: 48
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
