The Catalyst 9200 series delivers the superior features. It's highly secure and always on, and it provides IT simplicity, resulting in a great experience every time.
CONFIGURATION
48 x 10/100/1000M Ethernet with PoE+, 740W total PoE budget -
IT SIMPLIFIED
Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation -
SECURE
Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch -
ALWAYS-ON
Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies and fans, modular uplinks, 160 Gbps backplane stacking and layer 3 support -
MANAGEMENT
Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
- Cisco Catalyst 9200 - Essential Edition - switch - 48 ports - smart - rack-mountable
- Switch - 48 ports - smart - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 740 W
- Performance
- Wireless bandwidth: up to 48 Gbps , Switching capacity: 176 Gbps , Forwarding rate: 261.9 Mpps
- Capacity
- Virtual networks: 4 , MAC addresses: 32000 , IPv4 routes: 14000 , Indirect IPv4 routes: 4000 , Direct IPv4 routes: 10000 , IPv4 routing table entries: 4000 , IPv6 routing table entries: 2000 , Multicast scale: 1000 , ACL scale entries: 16000 , Packet buffer size: 6 MB , Flexible NetFlow entries: 16000 , VLAN IDs: 1000
- Jumbo Frame Support
- 9198 bytes
- Routing Protocol
- OSPF, RIP, IS-IS, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
- Remote Management Protocol
- NETCONF, RESTCONF
- QoS, RSPAN, FNF, MACsec support, CoPP, Sampled NetFlow, SPAN, EEM, FHS, DNA support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3bz
- Power
- AC 100-240 V
- Power Redundancy
- Optional
- 44.5 cm x 4.4 cm x 35 cm
- 5.5 kg
- System Requirements
- Cisco IOS XE 16.9.2 or later
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 740 W
- Performance
- Capacity
- 9198 bytes
- Routing Protocol
- NETCONF, RESTCONF
- RAM
- 4 GB
- Flash Memory
- 4 GB
- 48 x 1000Base-T RJ-45 PoE+ - 30 W
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Provided
- 1000 Watt
- Voltage Required
- AC 100-240 V
- MTBF
- 375,570 hours
- CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
- OS Required
- 44.5 cm
- 4.4 cm
- 35 cm
- 5.5 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
- -5 °C
- 45 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £78.27 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £39.55 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £19.57 |
