The Catalyst 9200 series delivers the superior features. It's highly secure and always on, and it provides IT simplicity, resulting in a great experience every time.
Super secure
Get advanced security features that protect the integrity of your hardware, software, and all data that flows through the switch.?? -
Always on
Catalyst 9200 series switches provide enterprise-level resiliency, analytics, and assurance to keep your business up and running seamlessly.
- Cisco Catalyst 9200 - Network Essentials - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000
- Performance
- Stacking bandwidth: 160 Gbps , Switching bandwidth: 176 Gbps , Forwarding rate: 261.9 Mpps
- Capacity
- Virtual networks: 4 , IPv4 routing table entries: 4000 , IPv6 routing table entries: 2000 , Flexible NetFlow entries: 16000 , Packet buffer size: 6 MB , VLAN IDs: 4096 , Switched virtual interfaces (SVIs): 1000
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 9198 bytes
- Routing Protocol
- OSPF, RIP, IS-IS, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
- ARP support, STP support, QoS, Rapid PVST+, SRR, PXE support, RSPAN, Energy Efficient Ethernet, MIB, CoS, FNF, Cisco StackWise-160 technology, DSCP support, MACsec support, CoPP, SPAN, EEM, PIM, FHS, PVLAN support, CIR
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 100-240 V (50 - 60 Hz)
- Power Redundancy
- Optional
- 44.5 cm x 35 cm x 4.4 cm
- 5 kg
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000
- Performance
- Capacity
- 32000 entries
- 9198 bytes
- Routing Protocol
- Encryption Algorithm
- 128-bit AES
- RAM
- 4 GB
- Flash Memory
- 4 GB
- 48 x 10/100/1000 Base-T RJ-45 , 1 x network stack device , 1 x management (LAN) RJ-45 , 1 x console RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Provided
- 125 Watt
- Voltage Required
- MTBF
- 571,440 hours
- CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
- 44.5 cm
- 35 cm
- 4.4 cm
- 5 kg
- 5 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £79.69 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £39.55 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £20.67 |
