Cisco Catalyst 9200 48-port Data switch Network Essentials
Quicklinx: G2PKWS00 Mfr#: C9200-48T-E
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
£1,681.12 ex VAT
£2,017.34 inc VAT
The Catalyst 9200 series delivers the superior features. It's highly secure and always on, and it provides IT simplicity, resulting in a great experience every time.
  • CONFIGURATION
    48 x 10/100/1000M Ethernet
  • IT SIMPLIFIED
    Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation
  • SECURE
    Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch
  • ALWAYS-ON
    Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies and fans, modular uplinks, 160 Gbps backplane stacking and layer 3 support
  • MANAGEMENT
    Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
Cisco Catalyst 9200 - Network Essentials - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Stacking bandwidth: 160 Gbps , Switching bandwidth: 176 Gbps , Forwarding rate: 261.9 Mpps
Virtual networks: 4 , IPv4 routing table entries: 4000 , IPv6 routing table entries: 2000 , Flexible NetFlow entries: 16000 , Packet buffer size: 6 MB , VLAN IDs: 4096 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP, IS-IS, RIP-1, RIP-2, EIGRP, VRRP, PIM-SM, EIGRP for IPv6, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng, MSTP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, CLI, NETCONF, RESTCONF
ARP support, STP support, QoS, Rapid PVST+, SRR, PXE support, RSPAN, Energy Efficient Ethernet, MIB, CoS, FNF, Cisco StackWise-160 technology, DSCP support, MACsec support, CoPP, SPAN, EEM, PIM, FHS, PVLAN support, CIR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
AC 100-240 V (50 - 60 Hz)
Power Redundancy
Optional
44.5 cm x 35 cm x 4.4 cm
5 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Encryption Algorithm
128-bit AES
RAM
4 GB
Flash Memory
4 GB
48 x 10/100/1000 Base-T RJ-45 , 1 x network stack device , 1 x management (LAN) RJ-45 , 1 x console RJ-45
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
125 Watt
MTBF
571,440 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
44.5 cm
35 cm
4.4 cm
5 kg
5 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
G2PK Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £81.46
G2PK Cisco Power Cable for Catalyst 3850-24 In Stock £41.16
G2PK Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.49
Ports: 48
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
