Cisco Catalyst 9200 - Network Essentials - switch - L3 - smart - 2
Quicklinx: G0M8WS00 Mfr#: C9200-24P-E
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
Hurry, only 1 left in stock!
£1,688.54 ex VAT
£2,026.24 inc VAT
The Catalyst 9200 series delivers the superior features. It's highly secure and always on, and it provides IT simplicity, resulting in a great experience every time.
  • CONFIGURATION
    24 x 10/100/1000M Ethernet with PoE+, 370W total PoE budget
  • IT SIMPLIFIED
    Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation.
  • SECURE
    Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch
  • ALWAYS-ON
    Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies and fans, modular uplinks, 160 Gbps backplane stacking and layer 3 support
  • MANAGEMENT
    Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
Cisco Catalyst 9200 - Network Essentials - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - L3 - smart - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
Performance
Stacking bandwidth: 160 Gbps , Switching bandwidth: 128 Gbps , Forwarding rate: 190.4 Mpps
Virtual networks: 4 , IPv4 routing table entries: 4000 , IPv6 routing table entries: 2000 , ACL scale entries: 1600 , Packet buffer size: 6 MB , VLAN IDs: 4096 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, VRRP, PIM-SSM, policy-based routing (PBR), RIPng
Remote Management Protocol
NETCONF, RESTCONF
Cisco StackWise Technology, EIGRP Stub Routing, FNF, MACsec support, built-in ASIC, CoPP, Blue Beacon LED, EEM, PIM, FHS, PVLAN support, DNA support, Superior QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3bz
AC 100-240 V (50 - 60 Hz)
Power Redundancy
Optional
4.4 cm x 44.5 cm x 35 cm
5.5 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
NETCONF, RESTCONF
Encryption Algorithm
128-bit AES
RAM
4 GB
Flash Memory
4 GB
Built-in Devices
RFID tag
24 x 10/100/1000 Base-T RJ-45 PoE+ - 30 W
Max Supported Qty
2
Power Redundancy
Optional
MTBF
422,310 hours
Plug and Play, CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
Software Included
Cisco Network Essentials
4.4 cm
44.5 cm
35 cm
5.5 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
G0M8 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.29
G0M8 Cisco Power Cable for Catalyst 3850-24 In Stock £41.91
G0M8 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.09
Ports: 24
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
