The Catalyst 9200 series delivers the superior features. It's highly secure and always on, and it provides IT simplicity, resulting in a great experience every time.
CONFIGURATION
24 x 10/100/1000M Ethernet with PoE+, 370W total PoE budget -
IT SIMPLIFIED
Catalyst 9200 Series switches simplify complexity, optimize IT, and reduce operational costs with Cisco UADP ASIC and Cisco IOS XE providing consistency, intelligence and automation. -
SECURE
Enhanced security with MACsec encryption, full flexible NetFlow, and trustworthy solutions that protect the integrity of the hardware as well as the software and all data that flows through the switch -
ALWAYS-ON
Differentiated resiliency with Field-Replaceable Units (FRU) and redundant power supplies and fans, modular uplinks, 160 Gbps backplane stacking and layer 3 support -
MANAGEMENT
Choice of CLI, Cisco Catalyst Center (formerly Cisco DNA Center) on-premises management, or cloud monitoring for Catalyst on Meraki dashboard
- Cisco Catalyst 9200 - Network Essentials - switch - 24 ports - smart - rack-mountable
- Switch - 24 ports - L3 - smart - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Stacking bandwidth: 160 Gbps , Switching bandwidth: 128 Gbps , Forwarding rate: 190.4 Mpps
- Capacity
- Virtual networks: 4 , IPv4 routing table entries: 4000 , IPv6 routing table entries: 2000 , ACL scale entries: 1600 , Packet buffer size: 6 MB , VLAN IDs: 4096 , Switched virtual interfaces (SVIs): 1000
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 9198 bytes
- Routing Protocol
- OSPF, RIP-1, RIP-2, VRRP, PIM-SSM, policy-based routing (PBR), RIPng
- Remote Management Protocol
- NETCONF, RESTCONF
- Cisco StackWise Technology, EIGRP Stub Routing, FNF, MACsec support, built-in ASIC, CoPP, Blue Beacon LED, EEM, PIM, FHS, PVLAN support, DNA support, Superior QoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3bz
- Power
- AC 100-240 V (50 - 60 Hz)
- Power Redundancy
- Optional
- 4.4 cm x 44.5 cm x 35 cm
- 5.5 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- Capacity
- 32000 entries
- 9198 bytes
- Routing Protocol
- NETCONF, RESTCONF
- Encryption Algorithm
- 128-bit AES
- RAM
- 4 GB
- Flash Memory
- 4 GB
- Built-in Devices
- RFID tag
- 24 x 10/100/1000 Base-T RJ-45 PoE+ - 30 W
- Power Device
- Internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Voltage Required
- MTBF
- 422,310 hours
- Plug and Play, CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, AS/NZS 60950-1, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, AS/NZS 3548 Class A, BSMI Class A, VCCI Class A, CNS 13438, EN 55022 Class A, EN 300 386, KN32, KN35, EN 55032 Class A, CISPR 32 Class A, CAN/CSA-C22.2 No. 60950-1, TCVN 7189 Class A, V-3 Class A, TCVN 7317, CISPR 35
- Software Included
- Cisco Network Essentials
- 4.4 cm
- 44.5 cm
- 35 cm
- 5.5 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day
- 5 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £81.10 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.99 |
