Cisco Catalyst 6500 48-Port Gigabit Switch (PoE)
Quicklinx: 6409WS00 Mfr#: WS-X6548GE45AF=
Designed for premier wiring closets, small campus backbone, and server farm applications, Cisco Express Forwarding 256 10/100/1000 Ethernet-over-copper interface modules provide line-rate 10/100 Ethernet forwarding and gigabit bandwidth options.
  • Robust connectivity
    Equipped with 48 RJ-45 connectors, this Cisco 256 Interface Module supports Ethernet 10Base-T/100Base-TX/1000Base-TX interfaces, ensuring versatile and reliable connectivity options for a wide range of network requirements.
  • Enhanced power delivery
    Featuring an 802.3af Power over Ethernet (PoE) daughter card, this module delivers power and data over a single cable, simplifying the deployment of devices such as IP cameras, VoIP phones, and wireless access points.
  • Comprehensive standards support
    Complies with a broad array of standards including IEEE 802.1D/Q/p/s/w, IEEE 802.3/ab/ad/af/x/z, ensuring interoperability and seamless integration into existing network infrastructures.
  • Advanced networking features
    Supports features such as Cisco Gigabit EtherChannel, Hot Standby Router Protocol (HSRP), and Virtual Route Redundancy Protocol (VRRP), enhancing network resilience and performance.
  • Efficient network management
    With support for SNMP 1, 2, 3, and RMON 1, 2, 3, 9, this module enables comprehensive remote management, facilitating efficient monitoring and management of network resources.
Cisco Express Forwarding 256 Interface Module with 802.3af PoE daughter card - expansion module - Gigabit Ethernet x 48
Expansion module
Plug-in module
Ports
35.6 cm x 40.6 cm x 3 cm
Cabling Type
Ethernet 10Base-T, Ethernet 1000Base-TX, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
Catalyst 6500, 6503, 6506, 6506 chassis, 6509, 6509 chassis, 6509-NEB, 6513
Expansion module
Plug-in module
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3
PoE, Cisco Gigabit EtherChannel, RSTP support, VRRP support, MSTP support, Jumbo Frames support, PVST+, PVRST, HSRP support
48 x 1000Base-TX (PoE) - RJ-45
Compatible Slots
1 x Expansion Slot
FCC Class A certified, CISPR 22 Class A, EN 60950, IEC950, UL 1950, VCCI Class A ITE, CSA 22.2 No. 950, EN55022 Class A, AS/NZS 3260, AS/NZ 3548 Class A, FCC CFR47 Part 15, FCC CFR21 Part 1040, EN 60825
35.6 cm
40.6 cm
3 cm
10 - 90% (non-condensing)
Cisco Catalyst 6500, 6503, 6506, 6506 chassis, 6509, 6509 chassis, 6509-NEB, 6513
