Designed to complement the many roles that the Cisco Catalyst 6500 Series plays in a network, Cisco Catalyst 6500 Series mixed media Gigabit Ethernet modules offer the broadest selection of media, densities, performance, interoperability, and chassis deployments for enterprises and service providers. These modules are ideal for gigabit Ethernet over fiber to the desktop, gigabit uplinks, aggregation of high-density 10/100 interfaces, Metro Ethernet, backbone and high-speed server farm or data center connections as well as mixed media environments supporting both fiber and copper cable connections.
Robust compatibility
Designed to seamlessly integrate with PC systems, this high performance Mixed Media Gigabit Ethernet Interface Module from Cisco ensures a smooth and reliable connection for a wide range of networking needs. -
Advanced connectivity
Featuring a Gigabit SFP port, this module offers high-speed wired connectivity, making it ideal for supporting demanding data and multimedia applications. -
Comprehensive environmental adaptability
Operates efficiently across a broad range of humidity (10 - 90%) and temperatures (0°C to 40°C), ensuring reliable performance in diverse operating conditions. -
Enhanced network management
With support for SNMP 1, 2, and 3, along with RMON 1, 2, 3, and 9, this module provides versatile and comprehensive management capabilities for efficient network monitoring and control. -
Standards compliance
Meets a wide array of compliance standards, including IEEE 802.1D/Q/p/s/w, 802.3ab/ad/x/z, ensuring interoperability and reliable performance across various network setups.
- Cisco High Performance Mixed Media Gigabit Ethernet Interface Module - switch - 48 ports - Managed - plug-in module
- Switch - 48 ports - Managed
- Enclosure Type
- Plug-in module
- Subtype
- Gigabit Ethernet
- Ports
- 48 x Gigabit SFP
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- HSRP, VRRP
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3
- Full duplex capability, VLAN support, Cisco Gigabit EtherChannel, manageable, RSTP support, MSTP support, QoS, PVST+, PVRST
- IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
- 35.6 cm x 40.6 cm x 3 cm
- Designed For
- Catalyst 6500, 6503, 6506, 6506 chassis, 6509, 6509 chassis, 6509 Wiring Closet Bundle, 6509-NEB, 6513
- Enclosure Type
- Plug-in module
- Subtype
- Gigabit Ethernet
- Compatible Slots
- 1 x Expansion Slot
- Ports
- 48 x Gigabit SFP
- 9216 bytes
- Routing Protocol
- HSRP, VRRP
- Status Indicators
- Status
- 48 x SFP (mini-GBIC)
- FCC Class A certified, VCCI, EN 60950, EN55022, UL 1950, IEC 60950, EN55024, CSA 22.2 No. 950, CISPR 22, ACA TS001, AS/NZS 3260, AS/NZS 3548, FCC CFR47 Part 15, FCC CFR21 Part 1040, EN 60825, IEC 60825-1
- 35.6 cm
- 40.6 cm
- 3 cm
- 0 °C
- 40 °C
- 10 - 90%
- Max Altitude Operating
- 4 km
- Designed For
- Cisco Catalyst 6500, 6503, 6506, 6506 chassis, 6509, 6509 chassis, 6509 Wiring Closet Bundle, 6509-NEB, 6513
