Cisco Catalyst 3850 48 Port UPOE IP Services
Quicklinx: C302WS00 Mfr#: WS-C3850-48U-E#SP
The Cisco Catalyst 3850 switch currently offers the industry's high 480 Gbps stacking bandwidth to meet network demand, including Gigabit desktop and 802.11ac wireless. The switch delivers advanced capabilities such as a high-performance 24/48 ports GE switch, 480G stacking, Power over Ethernet Plus, StackPower and flexible NetFlow on all ports.
The Cisco Catalyst 3850 switch brings Cisco IOS excellence to wireless by extending wired infrastructure features, resiliency, granular QoS, and scalability. It provides built-in wireless controller capabilities with 40G wireless throughput, support for 50 access points and 2000 wireless clients per switch or stack, and support for 802.11ac.
  • Best-in-class stackable access switch
  • Converged wired and wireless access
  • Distributed intelligent services
    The Cisco Catalyst 3850 switch delivers common intelligent services across wired and wireless for security and policy, application visibility and control, network resiliency, smart operations, and more. The switch can enable multi-level QoS based on granular information such as SSID, client, radio, application, and fair share policies for wireless.
  • Foundation for Cisco open network environment
    The heart of Cisco Catalyst 3850 is the ASIC with programmability for future features and intelligence with investment protection. The ASIC provides a foundation for converged APIs across wired and wireless, software-defined networking (SDN) support, and Cisco one platform kit (OnePK).
Cisco Catalyst 3850-48U-E - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (UPOE)
Power Over Ethernet (PoE)
UPOE
PoE Budget
800 W
Performance
Switching capacity: 176 Gbps , Stacking bandwidth: 480 Gbps
IPv4 routes: 24000 , NetFlow entries: 48000 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
BGP-4, IS-IS, RIP-1, RIP-2, EIGRP, PIM-SM, EIGRP for IPv6, OSPFv3, PIM-SSM, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH, CLI
Auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, IPv6 support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, RADIUS support, VRF-Lite, MLD snooping, DAI, STP Root Guard, UDLD, Rapid PVST+, IPv4 support, SRR, LACP, RSPAN, layer 3 load balancing, Energy Efficient Ethernet, UPOE, Cisco StackWise-480 technology, Cisco StackPower technology, FNF
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
Power Redundancy
Optional
44.5 cm x 45 cm x 4.45 cm
8 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
UPOE
PoE Budget
800 W
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
4 GB
Flash Memory
2 GB
Status Indicators
Port transmission speed, port duplex mode, system, status, PoE
48 x 1000Base-T RJ-45 UPOE - 60 W , 1 x USB Type A , 1 x management (mini-USB) Type B , 1 x serial (RS-232) RJ-45 management , 1 x management (Gigabit LAN) RJ-45 , 2 x network stack device
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
1100 Watt
MTBF
205,110 hours
CISPR 22 Class A, GOST, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, KCC, FCC Part 15 A, ISO 7779, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, CNS 13438(95) Class A, KN22 Class A, EN 55022 Class A
Software Included
Cisco IOS IP Services
44.5 cm
45 cm
4.45 cm
8 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
