Information technology professionals rely on Cisco quality to ensure maximum productivity. As the power of applications, processors, memory adapters and storage devices increases, high-end computer users are seeking ways to optimize their system performance. Cisco provides leading solutions, adding new levels of performance, availability, flexibility, and management.
Enhanced connectivity
The Cisco expansion module offers seamless integration for PCs, featuring a high-quality SFP (mini-GBIC) connector type that supports up to 4 network connections, ensuring reliable and efficient wired connectivity for your networking needs. -
Robust performance
Designed to meet the demands of high-speed networks, this module boasts a data transfer rate of 1 Gbps across its four ports. Its plug-in module form factor allows for easy installation and integration into existing systems, making it a versatile solution for expanding network capabilities. -
Durable design
With an impressive MTBF (Mean Time Between Failures) of over 7 million hours, this expansion module is built to last. Its durability ensures continuous operation and minimizes downtime, providing peace of mind and a reliable networking solution for businesses.
- Cisco - expansion module - 4 ports
- Expansion module
- Form Factor
- Plug-in module
- 300 g
- Ports Qty
- 4 ports
- Data Link Protocol
- 1GbE
- Data Transfer Rate
- 1 Gbps
- Designed For
- Catalyst 3850-12, 3850-12X48, 3850-24, 3850-48
- Expansion module - 4 ports
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Gigabit Ethernet
- 1 Gbps
- Status Indicators
- Port status
- 4 x network - SFP (mini-GBIC)
- Compatible Slots
- 1 x Expansion Slot
- MTBF
- 7,052,100 hours
- 300 g
- Designed For
- Cisco Catalyst 3850-12S-E, 3850-12S-S, 3850-12S-X, 3850-12X48U-E, 3850-12X48U-S, 3850-24P-BA, 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24S-E, 3850-24S-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-24U-E, 3850-24U-L, 3850-24U-S, 3850-24XU-E, 3850-24XU-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 3850-48U-E, 3850-48U-L, 3850-48U-S
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
