Cisco Catalyst 3850 4 x 1GE Network Module
Quicklinx: BP50WS00 Mfr#: C3850-NM-4-1G=
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Compatibility: PC
Type: Expansion module
£458.97 ex VAT
£550.76 inc VAT
Information technology professionals rely on Cisco quality to ensure maximum productivity. As the power of applications, processors, memory adapters and storage devices increases, high-end computer users are seeking ways to optimize their system performance. Cisco provides leading solutions, adding new levels of performance, availability, flexibility, and management.
  • Enhanced connectivity
    The Cisco expansion module offers seamless integration for PCs, featuring a high-quality SFP (mini-GBIC) connector type that supports up to 4 network connections, ensuring reliable and efficient wired connectivity for your networking needs.
  • Robust performance
    Designed to meet the demands of high-speed networks, this module boasts a data transfer rate of 1 Gbps across its four ports. Its plug-in module form factor allows for easy installation and integration into existing systems, making it a versatile solution for expanding network capabilities.
  • Durable design
    With an impressive MTBF (Mean Time Between Failures) of over 7 million hours, this expansion module is built to last. Its durability ensures continuous operation and minimizes downtime, providing peace of mind and a reliable networking solution for businesses.
Cisco - expansion module - 4 ports
Expansion module
Plug-in module
300 g
Ports Qty
4 ports
1GbE
Data Transfer Rate
1 Gbps
Catalyst 3850-12, 3850-12X48, 3850-24, 3850-48
Expansion module - 4 ports
Plug-in module
Wired
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Status Indicators
Port status
4 x network - SFP (mini-GBIC)
Compatible Slots
1 x Expansion Slot
MTBF
7,052,100 hours
300 g
Cisco Catalyst 3850-12S-E, 3850-12S-S, 3850-12S-X, 3850-12X48U-E, 3850-12X48U-S, 3850-24P-BA, 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24S-E, 3850-24S-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-24U-E, 3850-24U-L, 3850-24U-S, 3850-24XU-E, 3850-24XU-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 3850-48U-E, 3850-48U-L, 3850-48U-S
BP50 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.45
Compatibility: PC
Brand: Cisco
