Cisco Catalyst 3850 24 Port GE SFP IP Base
Quicklinx: DJG8WS00 Mfr#: WS-C3850-24S-S
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£17,896.92 ex VAT
£21,476.30 inc VAT
The Cisco Catalyst 3850 series is the enterprise-class stackable access-layer switches that provide full convergence between wired and wireless on a single platform. Cisco's Unified Access Data Plane (UADP) application-specific integrated circuit (ASIC) powers the switch and enables uniform wired-wireless policy enforcement, application visibility, flexibility and application optimization. The Cisco Catalyst 3850 series switches support full IEEE 802.3at Power over Ethernet Plus (PoE+), modular and field-replaceable network modules, redundant fans and power supplies.
  • Converged wired plus wireless access
    The Cisco Catalyst 3850 is the first stackable access switching platform that enables wired plus wireless services on a single Cisco IOS XE software-based platform. With this, Cisco has pioneered a host of rich capabilities such as high availability based on stateful switchover (SSO) on stacking, granular QoS, security, and Flexible Netflow (FNF) across wired and wireless in a seamless fashion.
  • Flexible NetFlow (FNF)
    Full visibility into the wired plus wireless traffic is achieved because of the access point Control and Provisioning of Wireless Access Points (CAPWAP) tunnel termination on the switch. This helps identify users and user traffic flows in order to identify potential attackers and take corrective action at the access layer before the attack penetrates further into the network. This is achieved using FNF, which monitors every single flow entering and exiting the switch stack for wired and wireless users. It also helps identify the top wired/wireless talkers and enforce appropriate bandwidth provisioning policies.
  • Advanced wired plus wireless QoS capabilities
    The 3850 switch has advanced wired plus wireless QoS capabilities. It uses the Cisco modular QoS command line interface (MQC). The switch manages wireless bandwidth using unprecedented hierarchical bandwidth management starting at the per-access-point level and drilling further down to per-radio, per-service set identification (SSID), and per-user levels. This helps manage and prioritize available bandwidth between various radios and various SSIDs (enterprise, guest, and so on) within each radio on a percentage basis. The switch is also capable of automatically allocating equal bandwidth among the connected users within a given SSID.
  • Provides a rich set of security features
    The Cisco Catalyst 3850 provides a rich set of security features for wired plus wireless users. Features such as IEEE 802.1x, Dynamic Host Configuration Protocol (DHCP) snooping, IP Source Guard and control plane protection, wireless intrusion prevention systems (WIPSs), and so on enable protection against unauthorized users and attackers. With a variety of wired plus wireless users connecting to the network, the switch supports session-aware networking, in which each device connected to the network is identified as one session, and unique access control lists (ACLs) and/or QoS policies can be defined and applied using the ISE for each of these sessions, providing better control on the devices connecting to the network.
Cisco Catalyst 3850-24S-S - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP
Performance
Switching capacity: 92 Gbps , Stacking bandwidth: 480 Gbps , Forwarding performance: 68.4 Mpps
IPv4 routes: 24000 , NetFlow entries: 24000 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
RIP-1, RIP-2, EIGRP, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH, CLI
DHCP support, auto-negotiation, ARP support, Syslog support, IDS, full duplex mode, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, QoS, DHCP server, DAI, Cisco StackWise Technology, URPF, UDLD, Rapid PVST+, SRR, LACP, Port Security, RSPAN, CAPWAP support, HSRP support, MIB, VRF, WIPS, CoS, Cisco StackPower technology, FNF, FTP client, DSCP support, Storm Control, IP source guard, WTD
IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
Power Redundancy
Optional
44.5 cm x 45 cm x 4.45 cm
7.03 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
4 GB
Flash Memory
2 GB
Status Indicators
24 x 1000Base-X SFP , 1 x USB Type A , 1 x management (mini-USB) Type B , 1 x serial (RS-232) RJ-45 management , 1 x management (Gigabit LAN) RJ-45 , 2 x network stack device
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
350 watt
MTBF
300,760 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN 55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, CCC, ICES-003 Class A, EN 61000-4-5, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, KCC, RoHS, FCC Part 15 A, AS/NZS 3548 Class A, BSMI Class A, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, CNS 13438(95) Class A, KN22 Class A, AS/NZS CISPR22:2004 Class A, CAN/CSA-C22.2 No. 60950-1, EN 300 386
Software Included
Cisco IOS IP Base
44.5 cm
45 cm
4.45 cm
7.03 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
DJG8 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.04
DJG8 Cisco Power Cable for Catalyst 3850-24 In Stock £40.73
DJG8 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.17
DJG8 Cisco 1m Type 1 Stacking Cable In Stock £236.95
DJG8 Cisco StackWise 480 Stacking Cable 3m for Catalyst 38 In Stock £229.96
DJG8 Cisco StackWise 480 Stacking Cable 50cm In Stock £107.69
DJG8 Cisco StackPower Power Cable 30cm In Stock £107.69
Ports: 24
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
