The Cisco Catalyst 3750-X series switches are an enterprise-class line of stackable switches. These switches provide high availability, scalability, security, energy efficiency, and ease of operation with innovative features such as Cisco StackPower, IEEE 802.3at Power over Ethernet Plus (PoE+) configurations, and Media Access Control Security (MACsec) features. The Cisco Catalyst 3750-X series with StackWise Plus technology provides scalability, ease of management and investment protection for the evolving business needs. The Cisco Catalyst 3750-X enhances productivity by enabling applications such as IP telephony, wireless, and video for borderless network experience.
Cisco StackWise Plus technology
Cisco StackWise Plus technology is built on the highly successful industry leading StackWise technology, which is a premium stacking architecture optimized for GbE. StackWise technology was designed to respond to additions, deletions, and redeployment while maintaining constant performance. StackWise creates a highly resilient single unified system of up to nine switches, providing simplified management using a single IP address, single telnet session, single command-line interface (CLI), auto-version checking, auto configuration, and more. StackWise Plus supports all the features of StackWise and provides backward compatibility with the existing Cisco Catalyst 3750 series switches while enhancing the throughput of the system up to 64Gbps. StackWise Plus also enables local switching in Cisco Catalyst 3750-X series switches. -
Cisco StackPower technology
The Cisco Catalyst 3750-X series introduces Cisco StackPower technology, innovative power interconnect system that allows the power supplies in a stack to be shared as a common resource among all the switches. Cisco StackPower unifies the individual power supplies installed in the switches and creates a pool of power, directing that power where it is needed. Up to four switches can be configured in a StackPower stack with the special connector at the back of the switch using the StackPower cable.
- Cisco Catalyst 3750X-48T-L - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000
- Performance
- Switching fabric bandwidth: 160 Gbps
- Capacity
- Virtual interfaces (VLANs): 255
- Jumbo Frame Support
- 9216 bytes
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
- Hot swap module replacement, Layer 2 switching, dynamic IP address assignment, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, High Availability, Multicast Storm Control, Unicast Storm Control, RSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping, DAI, Cisco StackWise Technology, PVST+, UDLD, SRR, LACP, RSPAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44.5 cm x 46 cm x 4.5 cm
- 7.4 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000
- Performance
- Capacity
- 9216 bytes
- Max Units In A Stack
- 9
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 256 MB
- Flash Memory
- 128 MB Flash
- Status Indicators
- Port status, port transmission speed, port duplex mode, power, system, link/activity
- 48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB Type A , 1 x console - mini-USB Type B management , 1 x RS-232 - RJ-45 management , 1 x 10Base-T/100Base-TX - RJ-45 management , 2 x network stack device
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Voltage Required
- Redundant Power System (RPS) connector
- Rack Mounting Kit
- Included
- MTBF
- 171,846 hours
- TUV GS, CISPR 22 Class A, GOST, cUL, NOM, VCCI Class A ITE, EN55022 Class A, CB, AS/NZS 60950-1, AS/NZ 3548 Class A, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 A, CSA C22.2 No. 60950-1
- Software Included
- Cisco IOS LAN Base
- 44.5 cm
- 46 cm
- 4.5 cm
- 7.4 kg
- Limited warranty - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
- -5 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
