Cisco Catalyst 3650-24TS-S Switch
Quicklinx: BTK4WS00 Mfr#: WS-C3650-24TS-S
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£1,680.08 ex VAT
£2,016.09 inc VAT
The Cisco Catalyst 3650 series is the enterprise-class standalone and stackable access-layer switch that provides the foundation for full convergence between wired and wireless on a single platform. The Cisco Catalyst 3650 takes advantage of the Cisco Unified Access Data Plane (UADP) application-specific integrated circuit (ASIC). This switch can enable uniform wired-wireless policy enforcement, application visibility, flexibility, application optimization, and superior resiliency. It can help you increase wireless productivity and reduce your TCO.
  • ETHERNET PORT CONFIGURATION
    24 10/100/1000 Gigabit Ethernet (GbE) ports; four 1 G uplinks
  • SOFTWARE
    IP base feature set
  • ADVANCED SECURITY
    IEEE 802.1x, DHCP (Dynamic Host Configuration Protocol) snooping, IP Source Guard and control plane protection and WIPSs (wireless intrusion prevention systems)
  • COMPACT
    Reduced depth of 11.62 inches (29.5 cm) for shallow-depth cabinets
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 3650-24TS-S - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x SFP
Performance
Switching capacity: 88 Gbps , Forwarding performance: 65.47 Mpps
IPv4 routes: 24000 , NetFlow entries: 24000 , Virtual interfaces (VLANs): 1000 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, SSH, CLI
Layer 2 switching, ARP support, trunking, VLAN support, IGMP snooping, RSTP support, MSTP support, DHCP snooping, PAgP support, ACL support, QoS, RADIUS support, MLD snooping, DAI, EIGRP Stub Routing, UDLD, Rapid PVST+, LACP, RSPAN, Energy Efficient Ethernet, FNF
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Power Redundancy
Optional
44.5 cm x 44.8 cm x 4.4 cm
6.87 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
4 GB
Flash Memory
2 GB
Status Indicators
Port transmission speed, port duplex mode, system, active, status
24 x 1000Base-T RJ-45 , 1 x USB Type A , 1 x serial (console) RJ-45 management , 1 x management (Gigabit LAN) RJ-45 management , 1 x management (mini-USB) Type B management , 4 x 1000Base-X SFP uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
250 Watt
Rack Mounting Kit
Included
MTBF
661,800 hours
CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, KCC, FCC Part 15 A, ISO 7779, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A
Software Included
Cisco IOS IP Base
44.5 cm
44.8 cm
4.4 cm
6.87 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
-5 °C
45 °C
5 - 96% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
BTK4 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £13.65
BTK4 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.09
BTK4 Cisco Power Cable for Catalyst 3850-24 In Stock £39.98
BTK4 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £19.60
Ports: 24
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
