Cisco Catalyst 3650 series switches are enterprise-class, stackable access switches that provide the foundation for full wired and wireless convergence on a single platform.
Facilitate wired-wireless policy enforcement, application visibility, flexibility, application optimization, and superior resiliency. Cisco Catalyst 3650 series switches are powered by the Cisco Unified Access Data Plane (UADP) ASIC and built on advanced Cisco StackWise-160 technology.
ETHERNET PORT CONFIGURATION
24 10/100/1000 Gigabit Ethernet (GbE) PoE+ ports; four 1 G uplinks -
SOFTWARE
LAN base feature set -
ADVANCED SECURITY
IEEE 802.1x, DHCP (Dynamic Host Configuration Protocol) snooping, IP Source Guard and control plane protection and WIPSs (wireless intrusion prevention systems) -
COMPACT
Reduced depth of 11.62 inches (29.5 cm) for shallow-depth cabinets -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 3650-24PS-L - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 4 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 390 W
- Performance
- Switching capacity: 88 Gbps , Forwarding performance: 41.66 Mpps
- Capacity
- IPv4 routes: 24000 , Virtual interfaces (VLANs): 255 , Switched virtual interfaces (SVIs): 1000
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 9198 bytes
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, SSH, CLI
- Full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, RADIUS support, MLD snooping, DAI, URPF, UDLD, Rapid PVST+, SRR, LLDP support, LACP, MAC Address Notification, RSPAN, HSRP support, Energy Efficient Ethernet, SPQ, CoS, DSCP support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44.5 cm x 44.8 cm x 4.4 cm
- 7.26 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 390 W
- Performance
- Capacity
- 32000 entries
- 9198 bytes
- Routing Protocol
- Static IP routing
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 4 GB
- Flash Memory
- 2 GB
- Status Indicators
- Port transmission speed, port duplex mode, system, active, status, PoE
- 24 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x USB Type A , 1 x serial (console) RJ-45 management , 1 x management (Gigabit LAN) RJ-45 management , 1 x management (mini-USB) Type B management , 4 x 1000Base-X SFP uplink
- Expansion Slots
- 1 (total) / 1 (free) x Stacking Module
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Power Provided
- 640 Watt
- Voltage Required
- Rack Mounting Kit
- Included
- MTBF
- 528,280 hours
- CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, KCC, FCC Part 15 A, ISO 7779, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A
- Software Included
- Cisco IOS LAN Base
- 44.5 cm
- 44.8 cm
- 4.4 cm
- 7.26 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
- -5 °C
- 45 °C
- 5 - 96% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £81.10 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.99 |
