Cisco Catalyst 3650 24 Port
Quicklinx: B39GWS00 Mfr#: WS-C3650-24PS-L
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
£1,770.67 ex VAT
£2,124.80 inc VAT
Cisco Catalyst 3650 series switches are enterprise-class, stackable access switches that provide the foundation for full wired and wireless convergence on a single platform.
Facilitate wired-wireless policy enforcement, application visibility, flexibility, application optimization, and superior resiliency. Cisco Catalyst 3650 series switches are powered by the Cisco Unified Access Data Plane (UADP) ASIC and built on advanced Cisco StackWise-160 technology.
  • ETHERNET PORT CONFIGURATION
    24 10/100/1000 Gigabit Ethernet (GbE) PoE+ ports; four 1 G uplinks
  • SOFTWARE
    LAN base feature set
  • ADVANCED SECURITY
    IEEE 802.1x, DHCP (Dynamic Host Configuration Protocol) snooping, IP Source Guard and control plane protection and WIPSs (wireless intrusion prevention systems)
  • COMPACT
    Reduced depth of 11.62 inches (29.5 cm) for shallow-depth cabinets
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 3650-24PS-L - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
390 W
Performance
Switching capacity: 88 Gbps , Forwarding performance: 41.66 Mpps
IPv4 routes: 24000 , Virtual interfaces (VLANs): 255 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, SSH, CLI
Full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, RADIUS support, MLD snooping, DAI, URPF, UDLD, Rapid PVST+, SRR, LLDP support, LACP, MAC Address Notification, RSPAN, HSRP support, Energy Efficient Ethernet, SPQ, CoS, DSCP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
Power Redundancy
Optional
44.5 cm x 44.8 cm x 4.4 cm
7.26 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
390 W
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Static IP routing
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
4 GB
Flash Memory
2 GB
Status Indicators
Port transmission speed, port duplex mode, system, active, status, PoE
24 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x USB Type A , 1 x serial (console) RJ-45 management , 1 x management (Gigabit LAN) RJ-45 management , 1 x management (mini-USB) Type B management , 4 x 1000Base-X SFP uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
640 Watt
Rack Mounting Kit
Included
MTBF
528,280 hours
CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, KCC, FCC Part 15 A, ISO 7779, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A
Software Included
Cisco IOS LAN Base
44.5 cm
44.8 cm
4.4 cm
7.26 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
-5 °C
45 °C
5 - 96% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
B39G C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
B39G C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.73
B39G Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.94
B39G Cisco Power Cable for Catalyst 3850-24 In Stock £38.19
B39G Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.67
Ports: 24
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
