Cisco Catalyst 3650-12X48UR-L Switch - L3 - Managed
Quicklinx: DHGJWS00 Mfr#: WS-C3650-12X48UR-L
Converge your wired and wireless network. Simplify operations, get the reliability you need, and deliver better mobile experiences to your employees and customers. With 3650 switches, your network is ready for the mobile devices and applications it needs to support.
  • Robust performance
    With a switching capacity of 472 Gbps and forwarding performance of 351.19 Mpps, the Cisco Catalyst 3650-12X48UR-L ensures efficient data handling for demanding network environments.
  • Comprehensive connectivity
    Equipped with 36 UPOE ports, 12 multi-gigabit UPOE ports, and 8 10 Gigabit SFP+ uplink ports, this switch offers versatile connectivity options for a wide range of devices and network layouts.
  • Advanced network security
    Features like Access Control List (ACL) support, Secure Shell (SSH), and RADIUS support provide a secure network environment by protecting against unauthorized access and ensuring data privacy.
  • Efficient power management
    The UPOE capability delivers up to 60 W per port, supporting energy-efficient operation of devices like VoIP phones, wireless access points, and surveillance cameras without the need for additional power supplies.
  • Reliable operation
    Designed for continuous operation with an MTBF of 201,680 hours and support for hot-plug power supplies, ensuring minimal downtime and maximum reliability for critical network infrastructures.
Cisco Catalyst 3650-12X48UR-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
36 x 10/100/1000 (UPOE) + 12 x 100/1000/2.5G/5G/10G (UPOE) + 8 x 10 Gigabit SFP+ (uplink)
Power Over Ethernet (PoE)
UPOE
PoE Budget
660 W
Performance
Switching capacity: 472 Gbps , Forwarding performance: 351.19 Mpps , Stacking bandwidth: 160 Gbps
IPv4 routes: 24000 , NetFlow entries: 24000 , Virtual interfaces (VLANs): 4094 , Switched virtual interfaces (SVIs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, RADIUS support, VRF-Lite, MLD snooping, DAI, Cisco StackWise Technology, URPF, UDLD, Rapid PVST+, SRR, LLDP support, LACP, MAC Address Notification, RSPAN, HSRP support, Energy Efficient Ethernet, SPQ, CoS, FNF, DSCP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
AC 120/230 V (50 - 60 Hz)
Power Redundancy
Optional
44.5 cm x 48.6 cm x 4.4 cm
8.08 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
UPOE
PoE Budget
660 W
Performance
32000 entries
Jumbo Frame Support
9198 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
4 GB
Flash Memory
4 GB
Status Indicators
Port transmission speed, port duplex mode, system, active, status, PoE
36 x 1000Base-T RJ-45 UPOE - 60 W , 1 x USB Type A , 1 x serial (console) RJ-45 management , 1 x management (Gigabit LAN) RJ-45 management , 1 x management (mini-USB) Type B management , 12 x 100/1000/2.5G/5G/10GBase-T RJ-45 UPOE - 60 W , 8 x 10GBase-X SFP+
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
1100 watt
Rack Mounting Kit
Included
MTBF
201,680 hours
CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, KCC, FCC Part 15 A, ISO 7779, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A, EN 55022 Class A
Software Included
Cisco IOS LAN Base
44.5 cm
48.6 cm
4.4 cm
8.08 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
-5 °C
45 °C
5 - 96% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
DHGJ Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.29
DHGJ Cisco Power Cable for Catalyst 3850-24 In Stock £41.91
DHGJ Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.09
