Cisco Catalyst 3560CX-8PC-S - Switch - Managed - 8 x 10/100/1000 (
Quicklinx: CWMNWS00 Mfr#: WS-C3560CX-8PC-S
The Cisco Catalyst 3560-CX series compact switches help optimize network deployments. These Gigabit Ethernet (GbE) managed switches are ideal for high-speed data connectivity, Wi-Fi back haul, and Power over Ethernet (PoE) connectivity in places where space is at a premium. Catalyst compact switches enable IP connectivity for devices such as IP phones, wireless access points, surveillance cameras, PCs, and video endpoints. With their quiet, fan-less design and compact footprint, these switches offer flexible mounting options and open up a variety of network design and connectivity options. Use them in offices, classrooms, hotels, retail stores, and other enterprise and branch locations.
  • ETHERNET PORT CONFIGURATION
    8 10/100/1000 Gigabit Ethernet (GbE) ports; 8 PoE+ output ports; two 1 G SFP uplinks; two 1 G copper uplinks
  • POWER CONSUMPTION
    24.4W at 100% throughput
  • FANLESS DESIGN
    Silent operation
  • DEFAULT SOFTWARE
    IP Base (IP Services with RTU Licence)
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 3560CX-8PC-S - switch - 8 ports - Managed
Switch - 8 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Forwarding performance (64-byte packet size): 17.9 Mpps
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP
Full duplex capability, Layer 3 switching, Layer 2 switching, auto-sensing per device, IP-routing, DHCP support, PoE, auto-negotiation, trunking, MPLS support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, manageable, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DHCP server, VRF-Lite, MLD snooping, DAI, TDR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
26.9 cm x 23.8 cm x 4.44 cm
2.27 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
240 W
Performance
Routing Protocol
Authentication Method
Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, port transmission speed, port duplex mode, power, link OK, system
8 x 1000Base-T RJ-45 PoE+ , 1 x 1000Base-T RJ-45 , 1 x SFP
Internal power supply
25.4 watt
MTBF
569,530 hours
FCC Class A certified, UL, TUV GS, cUL, EN 60950, EN55022, NOM, VCCI Class A ITE, IEC 60950, EN55024, UL 60950 Third Edition, CB, AS/NZ 3548 Class A, FCC Part 15, CSA C22.2 No. 60950-00, MIC
Software Included
Cisco IOS IP Base
26.9 cm
23.8 cm
4.44 cm
2.27 kg
-5 °C
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CWMN Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.70
CWMN Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
CWMN Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £19.94
