The Cisco Catalyst 3560-CX series compact switches help optimize network deployments. These Gigabit Ethernet (GbE) managed switches are ideal for high-speed data connectivity, Wi-Fi back haul, and Power over Ethernet (PoE) connectivity in places where space is at a premium. Catalyst compact switches enable IP connectivity for devices such as IP phones, wireless access points, surveillance cameras, PCs, and video endpoints. With their quiet, fan-less design and compact footprint, these switches offer flexible mounting options and open up a variety of network design and connectivity options. Use them in offices, classrooms, hotels, retail stores, and other enterprise and branch locations.
ETHERNET PORT CONFIGURATION
8 10/100/1000 Gigabit Ethernet (GbE) ports; 8 PoE+ output ports; two 1 G SFP uplinks; two 1 G copper uplinks -
POWER CONSUMPTION
24.4W at 100% throughput -
FANLESS DESIGN
Silent operation -
DEFAULT SOFTWARE
IP Base (IP Services with RTU Licence) -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 3560CX-8PC-S - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 240 W
- Performance
- Forwarding performance (64-byte packet size): 17.9 Mpps
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP
- Full duplex capability, Layer 3 switching, Layer 2 switching, auto-sensing per device, IP-routing, DHCP support, PoE, auto-negotiation, trunking, MPLS support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, manageable, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DHCP server, VRF-Lite, MLD snooping, DAI, TDR
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 26.9 cm x 23.8 cm x 4.44 cm
- 2.27 kg
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 240 W
- Performance
- Routing Protocol
- Authentication Method
- Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Port status, port transmission speed, port duplex mode, power, link OK, system
- 8 x 1000Base-T RJ-45 PoE+ , 1 x 1000Base-T RJ-45 , 1 x SFP
- Power Device
- Internal power supply
- Voltage Required
- 25.4 Watt
- MTBF
- 569,530 hours
- FCC Class A certified, UL, TUV GS, cUL, EN 60950, EN55022, NOM, VCCI Class A ITE, IEC 60950, EN55024, UL 60950 Third Edition, CB, AS/NZ 3548 Class A, FCC Part 15, CSA C22.2 No. 60950-00, MIC
- Software Included
- Cisco IOS IP Base
- 26.9 cm
- 23.8 cm
- 4.44 cm
- 2.27 kg
- -5 °C
- 45 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £80.17 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £39.23 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £20.49 |
