Cisco Catalyst 3560CX-12TC-S Switch 12 ports Managed - Desktop, Rack-Mountable, Wall-Mountable
Quicklinx: BQCWWS00 Mfr#: WS-C3560CX-12TC-S
Type: Gigabit Ethernet
Ports: 12
Managed: Yes
£838.98 ex VAT
£1,006.77 inc VAT
An effective work environment encourages collaboration. That often means tearing down office walls to create open workspaces. With their quiet, fan-less design, the switches create many possibilities for designing workspaces. They can reside nearly anywhere outside your wiring closet. Install them in carpeted areas such as offices, conference rooms, classrooms, and retail stores for quick, flexible connections. Rearrange rooms and floors without changing your cabling infrastructure. Consolidate cabling for big savings. Rather than running multiple Ethernet cables from endpoints like IP phones and Wi-Fi access points to a wiring closet, you just connect devices over a few feet of cabling to a nearby 3560-CX switch. Then connect the compact switch to the wiring closet with a single Ethernet or fiber cable. Using this setup, a 200-room hotel using compact switches in guest rooms can eliminate up to 30 kilometers of cables.
  • ETHERNET PORT CONFIGURATION
    12 10/100/1000 Gigabit Ethernet (GbE) ports; two 1 G SFP uplinks; two 1 G copper uplinks
  • POWER CONSUMPTION
    20.8W at 100% throughput
  • FANLESS DESIGN
    Silent operation
  • DEFAULT SOFTWARE
    IP Base (IP Services with RTU Licence)
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 3560CX-12TC-S - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Forwarding performance: 16 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
BOOTP support, ARP support, VLAN support, Syslog support, DiffServ support, IPv6 support, STP support, DHCP snooping, PAgP support, ACL support, QoS, fanless, SRR, MAC Address Notification, RSPAN, Energy Efficient Ethernet, MVR, CoS, WTD
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3az
26.9 cm x 21.3 cm x 4.44 cm
1.77 kg
Enclosure Type
Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, port transmission speed, port duplex mode, system, link/activity
12 x 1000Base-T RJ-45 , 1 x console RJ-45 , 1 x mini-USB Type B management , 1 x USB Type A , 2 x 1000Base-T RJ-45 uplink , 2 x SFP uplink
Internal power supply
Power Provided
300 Watt
17.3 Watt
80 PLUS Certification
80 PLUS Silver
Rack Mounting Kit
Optional
MTBF
755,270 hours
GOST, CISPR 24, EN55022, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ANATEL, GB 4943, KCC Class A, IEC 60825, KN22, KN24, VCCI V-3/2007.04 Class A, AS/NZS CISPR22:2004 Class A, CAN/CSA-C22.2 No. 60950-1
Software Included
Cisco IOS IP Base
26.9 cm
21.3 cm
4.44 cm
1.77 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
BQCW C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BQCW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.73
BQCW Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.94
BQCW Cisco Power Cable for Catalyst 3850-24 In Stock £40.45
BQCW Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.67
Ports: 12
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £750 - £1000
