An effective work environment encourages collaboration. That often means tearing down office walls to create open workspaces. With their quiet, fan-less design, the switches create many possibilities for designing workspaces. They can reside nearly anywhere outside your wiring closet. Install them in carpeted areas such as offices, conference rooms, classrooms, and retail stores for quick, flexible connections. Rearrange rooms and floors without changing your cabling infrastructure. Consolidate cabling for big savings. Rather than running multiple Ethernet cables from endpoints like IP phones and Wi-Fi access points to a wiring closet, you just connect devices over a few feet of cabling to a nearby 3560-CX switch. Then connect the compact switch to the wiring closet with a single Ethernet or fiber cable. Using this setup, a 200-room hotel using compact switches in guest rooms can eliminate up to 30 kilometers of cables.
ETHERNET PORT CONFIGURATION
12 10/100/1000 Gigabit Ethernet (GbE) ports; 8 PoE+ output ports; two 1 G SFP uplinks; two 1 G copper uplinks -
POWER CONSUMPTION
26.3W at 100% throughput -
FANLESS DESIGN
Silent operation -
DEFAULT SOFTWARE
IP Base (IP Services with RTU Licence) -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 3560CX-12PC-S - switch - 12 ports - Managed - rack-mountable
- Switch - 12 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 12 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 240 W
- Performance
- Forwarding performance: 16 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
- Capacity
- Virtual interfaces (VLANs): 1023
- Jumbo Frame Support
- 9018 bytes
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
- BOOTP support, ARP support, VLAN support, Syslog support, DiffServ support, IPv6 support, STP support, DHCP snooping, PAgP support, ACL support, QoS, fanless, SRR, MAC Address Notification, RSPAN, Energy Efficient Ethernet, MVR, CoS, WTD
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 26.9 cm x 23.8 cm x 4.44 cm
- 2.31 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 240 W
- Performance
- Capacity
- 9018 bytes
- Routing Protocol
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Port status, port transmission speed, port duplex mode, system, link/activity
- 12 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x console RJ-45 , 1 x mini-USB Type B management , 1 x USB Type A , 2 x 1000Base-T RJ-45 uplink , 2 x SFP uplink
- Power Device
- Internal power supply
- Power Provided
- 300 Watt
- Voltage Required
- 23.5 Watt
- 80 PLUS Certification
- 80 PLUS Silver
- Rack Mounting Kit
- Optional
- MTBF
- 553,140 hours
- GOST, CISPR 24, EN55022, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ANATEL, GB 4943, KCC Class A, IEC 60825, KN22, KN24, VCCI V-3/2007.04 Class A, AS/NZS CISPR22:2004 Class A, CAN/CSA-C22.2 No. 60950-1
- Software Included
- Cisco IOS IP Base
- 26.9 cm
- 23.8 cm
- 4.44 cm
- 2.31 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
- -5 °C
- 45 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £80.23 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.34 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £21.53 |
