Cisco CATALYST 3560 8 10/100 POE Switch
Quicklinx: 4KX1WS00 Mfr#: WS-C3560-8PC-S
The Cisco Catalyst 3560 Series is a line of fixed-configuration, enterprise-class switches that include IEEE 802.3af and Cisco prestandard Power over Ethernet (PoE) functionality in Fast Ethernet and Gigabit Ethernet configurations. The Cisco Catalyst 3560 is an ideal access layer switch for small enterprise LAN access or branch-office environments, combining both 10/100/1000 and PoE configurations for maximum productivity and investment protection while enabling the deployment of new applications such as IP telephony, wireless access, video surveillance, building management systems, and remote video kiosks. Customers can deploy networkwide intelligent services-such as advanced quality of service (QoS), rate limiting, access control lists (ACLs), multicast management, and high-performance IP routing-while maintaining the simplicity of traditional LAN switching. Available for the Cisco Catalyst 3560 Series at no charge, the Cisco Network Assistant is a centralized management application that simplifies the administration tasks for Cisco switches, routers, and wireless access points. Cisco Network Assistant provides configuration wizards that greatly simplify the implementation of converged networks and intelligent network services.
Cisco Catalyst 3560-8PC - switch - 8 ports - Managed
Switch - 8 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 1 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
12K entries
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH-2
Full duplex capability, Layer 3 switching, Layer 2 switching, auto-sensing per device, IP-routing, DHCP support, PoE, auto-negotiation, trunking, MPLS support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, manageable, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DHCP server, VRF-Lite, MLD snooping, DAI, TDR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
27 cm x 23 cm x 4.4 cm
2.3 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
PoE
12K entries
Routing Protocol
Authentication Method
Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
32 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, link OK, system
8 x 100Base-TX RJ-45 PoE , 1 x 1000Base-T RJ-45 , 1 x SFP (mini-GBIC)
Internal power supply
204 Watt
FCC Class A certified, UL, TUV GS, cUL, EN 60950, EN55022, NOM, VCCI Class A ITE, IEC 60950, EN55024, UL 60950 Third Edition, CB, AS/NZ 3548 Class A, FCC Part 15, CSA C22.2 No. 60950-00, MIC
Software Included
Cisco IOS IP Base
27 cm
23 cm
4.4 cm
2.3 kg
Limited warranty - lifetime
45 °C
10 - 85%
4KX1 Cisco 19in RackMount for Catalyst 3560,2960,ME-3400 In Stock £53.28
