The Cisco Catalyst 3560 Series is a line of fixed-configuration, enterprise-class switches that include IEEE 802.3af and Cisco prestandard Power over Ethernet (PoE) functionality in Fast Ethernet and Gigabit Ethernet configurations. The Cisco Catalyst 3560 is an ideal access layer switch for small enterprise LAN access or branch-office environments, combining both 10/100/1000 and PoE configurations for maximum productivity and investment protection while enabling the deployment of new applications such as IP telephony, wireless access, video surveillance, building management systems, and remote video kiosks. Customers can deploy networkwide intelligent services-such as advanced quality of service (QoS), rate limiting, access control lists (ACLs), multicast management, and high-performance IP routing-while maintaining the simplicity of traditional LAN switching. Available for the Cisco Catalyst 3560 Series at no charge, the Cisco Network Assistant is a centralized management application that simplifies the administration tasks for Cisco switches, routers, and wireless access points. Cisco Network Assistant provides configuration wizards that greatly simplify the implementation of converged networks and intelligent network services.
- Cisco Catalyst 3560-8PC - switch - 8 ports - Managed
- Switch - 8 ports - L3 - Managed
- Enclosure Type
- 1U
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE) + 1 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 12K entries
- Routing Protocol
- RIP-1, RIP-2, static IP routing, RIPng
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH-2
- Full duplex capability, Layer 3 switching, Layer 2 switching, auto-sensing per device, IP-routing, DHCP support, PoE, auto-negotiation, trunking, MPLS support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, manageable, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DHCP server, VRF-Lite, MLD snooping, DAI, TDR
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 27 cm x 23 cm x 4.4 cm
- 2.3 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- 12K entries
- Routing Protocol
- Authentication Method
- Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 128 MB
- Flash Memory
- 32 MB Flash
- Status Indicators
- Port status, port transmission speed, port duplex mode, power, link OK, system
- 8 x 100Base-TX RJ-45 PoE , 1 x 1000Base-T RJ-45 , 1 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- 204 watt
- FCC Class A certified, UL, TUV GS, cUL, EN 60950, EN55022, NOM, VCCI Class A ITE, IEC 60950, EN55024, UL 60950 Third Edition, CB, AS/NZ 3548 Class A, FCC Part 15, CSA C22.2 No. 60950-00, MIC
- Software Included
- Cisco IOS IP Base
- 27 cm
- 23 cm
- 4.4 cm
- 2.3 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 10 - 85%
Cisco 19in RackMount for Catalyst 3560,2960,ME-3400 | In Stock | £52.90 |
