Cisco Catalyst 2960XR-48LPS-I - Switch L3 Managed 48x10/100/1000
Quicklinx: DLLQWS00 Mfr#: WS-C2960XR-48LPS-I
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£8,030.20 ex VAT
£9,636.24 inc VAT
Cisco Catalyst 2960-X Series Switches are fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations with intelligent services and a range of advanced Cisco IOS software features.
  • Robust performance
    With a switching capacity of 216 Gbps and forwarding performance capable of processing 107.1 million packets per second, this device ensures efficient data flow and high-speed connectivity for demanding network environments.
  • Comprehensive connectivity
    Equipped with 48 10/100/1000 (PoE+) ports and 4 Gigabit SFP ports, this switch offers extensive connectivity options for a wide range of devices and applications, supporting both power and data over Ethernet.
  • Advanced network security
    Features such as Kerberos, RADIUS, Secure Shell (SSH), and TACACS+ provide multiple layers of network security, safeguarding against unauthorized access and ensuring secure communication channels.
  • Enhanced network management
    Support for SNMP, RMON, HTTP, and CLI allows for versatile and comprehensive management of the network, enabling efficient monitoring, configuration, and control of network resources.
  • Energy-efficient design
    Incorporating Cisco EnergyWise technology and Energy Efficient Ethernet, this switch optimizes power usage, reducing operational costs and contributing to a greener network environment.
Cisco Catalyst 2960XR-48LPS-I - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 107.1 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9216 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, HSRP, VRRP, PIM-SM, PIM-DM, PIM-SSM, policy-based routing (PBR), RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Layer 2 switching, PoE, auto-negotiation, ARP support, Cisco Fast EtherChannel, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IDS, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, RADIUS support, SSH support, Jumbo Frames support, MLD snooping, DAI, PoE+, Cisco EnergyWise technology, UDLD, Rapid PVST+, IPv4 support, SRR, LACP, MAC Address Notification, RSPAN, layer 3 load balancing, PVRST, NetFlow, HSRP support, Energy Efficient Ethernet, MVR, SPQ, CoS, Cisco FlexStack Plus
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 40.8 cm x 4.45 cm
6.4 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, port transmission speed, port duplex mode, system, RPS (Redundant Power Supply), PoE, link/activity
48 x 1000Base-T 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 12 ports (PoE+) / 48 ports (PoE) - 30 W , 1 x console SFP (mini-GBIC) - RJ-45 , 1 x mini-USB Type B management , 2 x USB Type A , 1 x 1000Base-TX RJ-45 management , 4 x SFP uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
640 Watt
Redundant Power System (RPS) connector
MTBF
274,380 hours
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2011/65/EU, VCCI Class A, KN24, KN22 Class A, EN 300386
Software Included
Cisco IOS IP Lite
44.5 cm
40.8 cm
4.45 cm
6.4 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
DLLQ Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.94
DLLQ Cisco Power Cable for Catalyst 3850-24 In Stock £38.19
DLLQ Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.67
Ports: 48
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
