Cisco Catalyst 2960XR-24TS-I Switch L3 Managed 24 x 10/10 + 4$
Quicklinx: CZT1WS00 Mfr#: WS-C2960XR-24TS-I
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£1,705.76 ex VAT
£2,046.91 inc VAT
Cisco Catalyst 2960-X series switch is a fixed-configuration, stackable Gigabit Ethernet switch that provides enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, it enables scalable, secure and energy-efficient business operations with intelligent services and a range of advanced Cisco IOS software features.
  • Robust security
    Equipped with Kerberos, RADIUS, Secure Shell (SSH), and TACACS+ authentication methods, this switch ensures secure network access and management, safeguarding against unauthorized access and threats.
  • High performance
    With a switching capacity of 216 Gbps and forwarding performance of 71.4 Mpps, the Cisco Catalyst 2960XR-24TS-I efficiently manages data traffic, ensuring smooth and reliable network performance.
  • Enhanced manageability
    Support for SNMP, RMON, CLI, and more, allows for comprehensive remote management, facilitating easier configuration, monitoring, and troubleshooting of the network.
  • Advanced networking features
    Features such as Layer 3 switching, NetFlow, Quality of Service (QoS), and IPv6 support, provide the tools needed for advanced network management and optimization.
  • Flexible connectivity
    With 24 10/100/1000 ports and 4 SFP (mini-GBIC) ports, this switch offers a variety of connectivity options for different network needs, including high-speed uplinks and management interfaces.
Cisco Catalyst 2960XR-24TS-I - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x SFP
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 71.4 Mpps
Active VLANs: 1023
Jumbo Frame Support
9216 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, HSRP, VRRP, PIM-SM, PIM-DM, OSPFv3, PIM-SSM, policy-based routing (PBR), RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Full duplex capability, Layer 2 switching, auto-negotiation, BOOTP support, ARP support, Cisco Fast EtherChannel, VLAN support, auto-uplink (auto MDI/MDI-X), Cisco Gigabit EtherChannel, IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, RADIUS support, Jumbo Frames support, MLD snooping, DAI, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, SRR, DHCP relay, LACP, MAC Address Notification, RSPAN, layer 3 load balancing, PVRST, NetFlow, HSRP support, Energy Efficient Ethernet, MVR, SPQ, CoS, Cisco FlexStack Plus, DSCP support, IGMP filtering
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 40.8 cm x 4.45 cm
5.9 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Active VLANs: 1023
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, port transmission speed, port duplex mode, system, link/activity
24 x 1000Base-T RJ-45 , 1 x console RJ-45 , 1 x mini-USB Type B management , 2 x USB Type A , 1 x 100Base-TX RJ-45 management , 4 x SFP uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
250 watt
Rack Mounting Kit
Included
MTBF
557,320 hours
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A, RoHS 2011/65/EU, EN 55022 Class A, EN 300 386
Software Included
Cisco IOS IP Lite
44.5 cm
40.8 cm
4.45 cm
5.9 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CZT1 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.70
CZT1 Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
CZT1 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £21.11
Ports: 24
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
