Cisco Catalyst 2960-X series switches are fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations.
ETHERNET PORT CONFIGURATION
48 10/100/1000 Gigabit Ethernet ports, four 1 G SFP uplink ports -
DEVICE MANAGEMENT
Web UI, over-the-air access via Bluetooth and CLI (command-line interface) -
CONSOLE ACCESS
SNMP (Simple Network Management Protocol) and RJ-45 or USB console access -
SECURITY
802.1X, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 2960X-48TS-L - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x Gigabit SFP
- Performance
- Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 107.1 Mpps
- Capacity
- Virtual interfaces (VLANs): 1023
- Jumbo Frame Support
- 9216 bytes
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
- Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IPv6 support, RSTP support, MSTP support, DTP support, PAgP support, TFTP support, ACL support, RADIUS support, Jumbo Frames support, MLD snooping, DAI, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, IPv4 support, SRR, LACP, RSPAN, NetFlow, HSRP support, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1ae, IEEE 802.3az, IEEE 802.1AX
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44.5 cm x 27.9 cm x 4.5 cm
- 4.2 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 9216 bytes
- Max Units In A Stack
- 8
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- Processor
- : 600 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Port transmission speed, port duplex mode, system, status, link/activity
- 48 x 1000Base-T 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 , 1 x console console - RJ-45 - RJ-45 , 1 x mini-USB console - mini-USB Type B - Type B management , 1 x USB Type A , 1 x 1000Base-TX 10Base-T/100Base-TX - RJ-45 - RJ-45 management , 4 x SFP (mini-GBIC) - SFP uplink
- Expansion Slots
- 1 (total) / 1 (free) x Stacking Module
- Power Device
- Internal power supply
- Power Redundancy
- Optional
- Voltage Required
- Redundant Power System (RPS) connector
- MTBF
- 442,690 hours
- CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN22, KN24, CNS 13438(95) Class A, EN 55022 Class A, EN 300 386
- Software Included
- Cisco IOS LAN Base
- 44.5 cm
- 27.9 cm
- 4.5 cm
- 4.2 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
- -5 °C
- 45 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £79.70 |
Cisco AC Power Cord | In Stock | £40.46 |
