Cisco Catalyst 2960X-48LPD-L Switch Managed 48 x 10/10
Quicklinx: B7Z6WS00 Mfr#: WS-C2960X-48LPD-L
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 100Mbps
Managed: Yes
POE: PoE+
£2,860.31 ex VAT
£3,432.37 inc VAT
Cisco Catalyst 2960-X series switch is fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations with intelligent services and a range of advanced Cisco IOS software features.
  • ETHERNET PORT CONFIGURATION
    48 10/100/1000 Gigabit Ethernet ports, two 10 G SFP+ uplink ports
  • POWER
    PoE+ support with a power budget of up to 370W and Perpetual PoE; max. of 24 PoE ports (or 12 PoE+ ports)
  • DEVICE MANAGEMENT
    Web UI, over-the-air access via Bluetooth, CLI (command-line interface), SNMP (Simple Network Management Protocol) and RJ-45 or USB console access
  • SECURITY
    802.1X, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 2960X-48LPD-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 130.9 Mpps
Active VLANs: 1023
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Full duplex capability, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, MLD snooping, DAI, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, SRR, LLDP support, DHCP relay, LACP, MAC Address Notification, RSPAN, HSRP support, Energy Efficient Ethernet, MIB, MVR, SPQ, CoS, Cisco FlexStack Plus, DSCP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 36.8 cm x 4.5 cm
5.8 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
Active VLANs: 1023
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port transmission speed, port duplex mode, system, status, RPS (Redundant Power Supply), PoE, link/activity
48 x 1000Base-T RJ-45 12 ports (PoE+) / 24 ports (PoE) , 1 x console RJ-45 , 1 x mini-USB Type B management , 1 x USB Type A , 1 x 100Base-TX RJ-45 management , 2 x SFP+ uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Power Redundancy
Optional
45.7 Watt
Redundant Power System (RPS) connector
MTBF
277,960 hours
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A, RoHS 2011/65/EU, EN 300386
Software Included
Cisco IOS LAN Base
44.5 cm
36.8 cm
4.5 cm
5.8 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
B7Z6 Cisco 10GBASE-SR SFP Module In Stock £364.51
B7Z6 Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £114.56
B7Z6 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
B7Z6 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
B7Z6 Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.18
B7Z6 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.43
B7Z6 Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £75.29
B7Z6 Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £61.27
B7Z6 Cisco SFP+ Transceiver Module In Stock £424.80
B7Z6 Cisco AC Power Cord In Stock £40.81
B7Z6 Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £101.75
B7Z6 Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC In Stock £1,486.56
Ports: 48
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
