Cisco Catalyst 2960-X series switches are fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations.
ETHERNET PORT CONFIGURATION
48 10/100/1000 Gigabit Ethernet ports, four 1 G SFP uplink ports -
POWER
PoE+ support with a power budget of up to 740W and Perpetual PoE; max of 48 PoE ports (or 24 PoE+ ports) -
DEVICE MANAGEMENT
Web UI, over-the-air access via Bluetooth, CLI (command-line interface), SNMP (Simple Network Management Protocol) and RJ-45 or USB console access -
SECURITY
802.1X, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard -
PEACE OF MIND
Enhanced limited lifetime warranty
 - Cisco Catalyst 2960X-48FPS-L - switch - 48 ports - Managed - rack-mountable
 - Switch - 48 ports - Managed - stackable
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 48 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 740 W
- Performance
 - Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 107.1 Mpps
- Capacity
 - Virtual interfaces (VLANs): 1023
- Jumbo Frame Support
 - 9216 bytes
- Remote Management Protocol
 - SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
 - Layer 2 switching, DHCP support, PoE, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IDS, IPv6 support, RSTP support, MSTP support, DTP support, PAgP support, TFTP support, ACL support, RADIUS support, SSH support, Jumbo Frames support, MLD snooping, DAI, PoE+, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, IPv4 support, SRR, LACP, MAC Address Notification, RSPAN, NetFlow, HSRP support, Energy Efficient Ethernet, MVR, CoS, Cisco FlexStack Plus
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
- Power
 - AC 120/230 V (50/60 Hz)
- Power Redundancy
 - Optional
 - 44.5 cm x 36.8 cm x 4.5 cm
 - 5.8 kg
 - Limited lifetime warranty
- Enclosure Type
 - Desktop, rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 740 W
- Performance
- Capacity
 - 9216 bytes
- Max Units In A Stack
 - 8
- Authentication Method
 - Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- Processor
 - : 600 MHz
- RAM
 - 512 MB
- Flash Memory
 - 128 MB
- Status Indicators
 - Port status, port transmission speed, port duplex mode, system, RPS (Redundant Power Supply), PoE, link/activity
 - 48 x 1000Base-T 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 PoE+ - 30 W , 1 x console console - RJ-45 - RJ-45 , 1 x mini-USB console - mini-USB Type B - Type B management , 2 x USB Type A , 1 x 1000Base-TX 10Base-T/100Base-TX - RJ-45 - RJ-45 management , 4 x SFP (mini-GBIC) - SFP uplink
- Expansion Slots
 - 1 (total) / 1 (free) x Stacking Module
- Power Device
 - Internal power supply
- Power Redundancy
 - Optional
- Voltage Required
 - Redundant Power System (RPS) connector
- MTBF
 - 232,610 hours
 - CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2011/65/EU, VCCI Class A, KN24, KN22 Class A, EN 300386
- Software Included
 - Cisco IOS LAN Base
 - 44.5 cm
 - 36.8 cm
 - 4.5 cm
 - 5.8 kg
 - Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
 - -5 °C
 - 45 °C
 - 10 - 95% (non-condensing)
- Min Storage Temperature
 - -25 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
                        C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
                        C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
                        Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £81.10 |
                        Cisco AC Power Cord | In Stock | £41.18 |
