Cisco Catalyst 2960X-24TS-LL Switch Managed 24 x 10/10
Quicklinx: 9S57WS00 Mfr#: WS-C2960X-24TS-LL
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 100Mbps
Managed: Yes
£858.01 ex VAT
£1,029.61 inc VAT
Cisco Catalyst 2960-X series switches are fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations.
  • Network security
    The Cisco Catalyst 2960-X series switches provide a range of security features to limit access to the network and mitigate threats.
  • Redundancy and resiliency
    Cisco Catalyst 2960-X series switches offer a number of redundancy and resiliency features to prevent outages and help ensure that the network remains available.
  • Enhanced Quality of Service
    The Cisco Catalyst 2960-X series switches offers intelligent traffic management that keeps everything flowing smoothly. Flexible mechanisms for marking, classification, and scheduling deliver superior performance for data, voice, and video traffic, all at wire speed.
  • Application visibility
    Catalyst 2960-X series switches support NetFlow Lite, which enables IT teams to understand the mix of traffic on their network and identify anomalies by capturing and recording specific packet flows. NetFlow Lite supports flexible sampling of the traffic, and exports flow data in the NetFlow Version 9 format for analysis on a wide range of Cisco and third-party collectors.
  • Cisco Catalyst SmartOperations
    Cisco Catalyst SmartOperations is a comprehensive set of capabilities that simplify LAN planning, deployment, monitoring, and troubleshooting. Deploying SmartOperations tools reduces the time and effort required to operate the network and lowers total cost of ownership (TCO).
  • Power management
    The 2960-X series switches offer a range industry leading features for effective energy efficiency and energy management.
  • Network management
    The Cisco Catalyst 2960-X series switches offer a superior CLI for detailed configuration and administration. 2960-X series switches are also supported in the full range of Cisco network management solutions.
  • Security management
    Cisco Identity Services Engine (ISE) support enables the 2960-X series of switches to offer security management for all devices connected to it.
Cisco Catalyst 2960X-24TS-LL - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x Gigabit SFP
Performance
Switching capacity: 100 Gbps , Forwarding performance (64-byte packet size): 68.5 Mpps
Virtual interfaces (VLANs): 64
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IPv6 support, RSTP support, MSTP support, DTP support, PAgP support, TFTP support, ACL support, RADIUS support, Jumbo Frames support, MLD snooping, DAI, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, IPv4 support, SRR, LACP, RSPAN, NetFlow, HSRP support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1ae, IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 27.9 cm x 4.5 cm
3.7 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
64 MB
Status Indicators
Port transmission speed, port duplex mode, system, status, link/activity
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x console - RJ-45 management , 1 x console - mini-USB Type B management , 1 x USB Type A , 1 x 10Base-T/100Base-TX - RJ-45 management , 2 x SFP (mini-GBIC)
Internal power supply
Power Redundancy
Optional
Redundant Power System (RPS) connector
MTBF
622,350 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN22, KN24, CNS 13438(95) Class A, EN 55022 Class A, EN 300 386
Software Included
Cisco IOS LAN Lite
44.5 cm
27.9 cm
4.5 cm
3.7 kg
Limited warranty - advance parts replacement - lifetime - response time: 10 days , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
9S57 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
9S57 Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.14
9S57 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.29
9S57 Cisco AC Power Cord In Stock £40.75
9S57 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.09
Ports: 24
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £750 - £1000
