Cisco Catalyst 2960S Stack 48 GigE PoE 370W, 2 x 10G SFP+ LAN Base
Quicklinx: 7RTHWS00 Mfr#: WS-C2960S-48LPD-L
The Cisco Catalyst 2960S Series Switches are the leading layer 2 edge, providing improved ease of use, highly secure business operations, improved sustainability, and a borderless network experience. The Cisco Catalyst 2960S Series Switches include Cisco FlexStack switch stacking capability with 1 and 10 Gigabit connectivity. The Cisco Catalyst 2960S Series are fixed-configuration access switches designed for enterprise, midmarket, and branch office networks to provide lower total cost of ownership.
  • Efficient switch operation
    Cisco Catalyst 2960S Series Switches, designed and engineered by Cisco, provide optimum power saving, low power operations for industry best-in-class power management, and power consumption capabilities. The Cisco Catalyst 2960S ports are capable of reduced power modes so that ports not in use can move into a lower power utilization state.
  • Intelligent Power over Ethernet management
    The Cisco Catalyst 2960S PoE models support the PoE+ devices including Cisco IP phones and Cisco Aironet WLAN access points providing up to 30W of power per port, as well as any IEEE 802.3af-compliant end device.
  • Enhanced quality of service
    The Cisco Catalyst 2960S Series Switches offers intelligent services that keep everything flowing smoothly. Industry-leading mechanisms for marking, classification, and scheduling deliver superior performance for data, voice, and video traffic, all at wire speed.
Cisco Catalyst 2960S-48LPD-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 101.2 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
Layer 2 switching, auto-sensing per device, dynamic IP address assignment, PoE, auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, QoS, PoE+, LACP, Port Security, MAC Address Notification, RSPAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3at
44.5 cm x 38.6 cm x 4.5 cm
5.77 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x USB Type A , 1 x console - mini-USB Type B management , 1 x console - RJ-45 management , 1 x 10Base-T/100Base-TX - RJ-45 management , 2 x SFP+
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
71 watt
Rack Mounting Kit
Optional
MTBF
198,300 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, VCCI Class A ITE, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Base
44.5 cm
38.6 cm
4.5 cm
5.77 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
7RTH Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.26
7RTH Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.04
