Simplify operations, get the reliability you need, and deliver better mobile experiences to your employees and customers. Make your network ready for the mobile devices and applications it needs to support with the 2960L, all at a great value.
ETHERNET PORT CONFIGURATION
8 10/100/1000 Gigabit Ethernet ports, two 1 G SFP uplink ports -
POWER
Power budget of 67W with Perpetual PoE+ support for uninterrupted power to PoE devices, even in case of switch reboot -
MANAGEMENT
Manage the switch via the Cisco IOS CLI (command-line interface) and/or intuitive web UI; additionally, access the switch over-the-air using an external Bluetooth adapter -
SECURITY
802.1X support for connected devices, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 2960L-8PS-LL - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 + 2 x Gigabit SFP (uplink)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 67 W
- Performance
- Switching bandwidth: 20 Gbps , Forwarding bandwidth: 10 Gbps
- Capacity
- MAC addresses: 8000 , VLANs supported: 4094 , Active VLANs: 64 , SPAN bidirectional sessions: 1
- Jumbo Frame Support
- 10240 bytes
- Routing Protocol
- IGMP
- Remote Management Protocol
- SNMP 3, CLI
- Layer 2 switching, ARP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, RADIUS support, DAI, Cisco EnergyWise technology, UDLD, fanless, LACP, MAC Address Notification, PVRST, per-port broadcast throttling, GVRP, SNMP support, IGMP filtering, VTP, BPDU, STRG, NTP
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.3ah, IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 26.8 cm x 24 cm x 4.4 cm
- 2.56 kg
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 67 W
- Performance
- Capacity
- 10240 bytes
- Routing Protocol
- IGMP
- SNMP 3, CLI
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- Processor
- ARM7: 800 MHz
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- System, status, PoE, link/speed
- 8 x 1000Base-T RJ-45 , 1 x console RJ-45 , 1 x console (mini-USB) Type B , 1 x USB Type A , 2 x 1000Base-X SFP uplink
- Power Device
- Internal power supply
- Voltage Required
- MTBF
- 2,416,689 hours
- CISPR 22 Class A, CISPR 24, EN55024, AS/NZS 60950-1, ICES-003 Class A, UL 60950-1, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, RoHS 2011/65/EU, AS/NZS CISPR22:2004 Class A, EN 55022 Class A, FCC CFR47 Part 15 B Class A, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 300 386
- Software Included
- Cisco IOS LAN Lite
- 26.8 cm
- 24 cm
- 4.4 cm
- 2.56 kg
- -5 °C
- 55 °C
- 5 - 90%
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95%
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £34.89 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £79.70 |
Cisco AC Power Cord | In Stock | £40.46 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £19.94 |
