Cisco Catalyst 2960L-8PS-LL 8-port Managed Gigabit SFP Switch
Quicklinx: F0M8WS00 Mfr#: WS-C2960L-8PS-LL
Simplify operations, get the reliability you need, and deliver better mobile experiences to your employees and customers. Make your network ready for the mobile devices and applications it needs to support with the 2960L, all at a great value.
  • ETHERNET PORT CONFIGURATION
    8 10/100/1000 Gigabit Ethernet ports, two 1 G SFP uplink ports
  • POWER
    Power budget of 67W with Perpetual PoE+ support for uninterrupted power to PoE devices, even in case of switch reboot
  • MANAGEMENT
    Manage the switch via the Cisco IOS CLI (command-line interface) and/or intuitive web UI; additionally, access the switch over-the-air using an external Bluetooth adapter
  • SECURITY
    802.1X support for connected devices, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 2960L-8PS-LL - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x Gigabit SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
67 W
Performance
Switching bandwidth: 20 Gbps , Forwarding bandwidth: 10 Gbps
MAC addresses: 8000 , VLANs supported: 4094 , Active VLANs: 64 , SPAN bidirectional sessions: 1
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP
Remote Management Protocol
SNMP 3, CLI
Layer 2 switching, ARP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, RADIUS support, DAI, Cisco EnergyWise technology, UDLD, fanless, LACP, MAC Address Notification, PVRST, per-port broadcast throttling, GVRP, SNMP support, IGMP filtering, VTP, BPDU, STRG, NTP
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.3ah, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
26.8 cm x 24 cm x 4.4 cm
2.56 kg
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
67 W
Performance
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP
SNMP 3, CLI
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
ARM7: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
System, status, PoE, link/speed
8 x 1000Base-T RJ-45 , 1 x console RJ-45 , 1 x console (mini-USB) Type B , 1 x USB Type A , 2 x 1000Base-X SFP uplink
Internal power supply
MTBF
2,416,689 hours
CISPR 22 Class A, CISPR 24, EN55024, AS/NZS 60950-1, ICES-003 Class A, UL 60950-1, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, RoHS 2011/65/EU, AS/NZS CISPR22:2004 Class A, EN 55022 Class A, FCC CFR47 Part 15 B Class A, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 300 386
Software Included
Cisco IOS LAN Lite
26.8 cm
24 cm
4.4 cm
2.56 kg
-5 °C
55 °C
5 - 90%
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95%
F0M8 Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.26
F0M8 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.04
F0M8 Cisco AC Power Cord In Stock £40.90
F0M8 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.17
