Cisco Catalyst 2960L-48TQ-LL - Switch - Managed - 48 x 10/10
Quicklinx: F58BWS00 Mfr#: WS-C2960L-48-TQ-LL
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
£2,034.19 ex VAT
£2,441.02 inc VAT
Simplify operations, get the reliability you need, and deliver better mobile experiences to your employees and customers. The Cisco Catalyst 2960-L supports Power over Ethernet (PoE). Make your network ready for the mobile devices and applications it needs to support with the 2960-L, all at a great value.
  • ETHERNET PORT CONFIGURATION
    48 10/100/1000 Gigabit Ethernet ports, four 10 G SFP+ uplink ports
  • MANAGEMENT
    Manage the switch via the Cisco IOS CLI (command-line interface) and/or intuitive web UI
  • OVER-THE-AIR
    Access the switch over-the-air using an external Bluetooth adapter
  • SECURITY
    802.1X support for connected devices, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 2960L-48TQ-LL - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 1 Gigabit / 10 Gigabit SFP+
Performance
Switching bandwidth: 176 Gbps , Forwarding bandwidth: 88 Gbps , Forwarding performance (64-byte packet size): 77.38 Mpps
VLANs supported: 4094 , Active VLANs: 64 , STP instances: 64 , SPAN sessions: 1
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 2, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
DHCP support, auto-negotiation, BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), IDS, WRR queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, DAI, Cisco EnergyWise technology, UDLD, Rapid PVST+, fanless, LACP, Port Security, Energy Efficient Ethernet, MIB, GVRP, CoS, IGMP filtering, WTD, VTP, BPDU, ICMP, STRG, NTP
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.3az, IEEE 802.1AX
AC 120/230 V (50 - 60 Hz)
44.5 cm x 24 cm x 4.4 cm
3.03 kg
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMP, MLDv2, MLD
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
ARM7: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Port status, port duplex mode, system, link/speed
48 x 1000Base-T RJ-45 , 1 x console RJ-45 , 1 x console (mini-USB) Type B , 1 x USB Type A , 4 x 10GBase-X SFP+ uplink
Internal power supply
MTBF
1,370,769 hours
Plug and Play, CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2011/65/EU, VCCI Class A, KN24, KN22 Class A, AS/NZS CISPR22:2004 Class A, EN 55022 Class A, FCC CFR47 Part 15 A, CNS 13438 Class A, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 300 386, USGv6
Software Included
Cisco IOS LAN Lite
44.5 cm
24 cm
4.4 cm
3.03 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
55 °C
5 - 90%
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95%
F58B Cisco 10GBASE-SR SFP Module In Stock £365.80
F58B Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £114.18
F58B Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.28
F58B Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.64
F58B Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £76.67
F58B Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £62.29
F58B Cisco AC Power Cord In Stock £40.93
F58B Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £20.19
F58B Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £102.64
F58B Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC In Stock £1,512.23
Ports: 48
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
