Cisco Catalyst 2960CX-8PC-L Switch Managed 8 x 10/100/1000
Quicklinx: BMXPWS00 Mfr#: WS-C2960CX-8PC-L
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
£619.65 ex VAT
£743.58 inc VAT
The Cisco Catalyst Compact Switches easily expand your Catalyst switching infrastructure outside the wiring closet to enable workspaces, extend wireless LANs, and connect PoE devices. These fan-less, small form-factor switches are ideal for space-constrained deployments where multiple cable runs would be challenging.
The Cisco Catalyst 2960-CX compact switches help optimize network deployments. These Gigabit Ethernet (GbE) managed switches are ideal for high-speed data connectivity, Wi-Fi backhaul, and Power over Ethernet (PoE) connectivity in places where space is at a premium. With a single copper or fiber cable from the wiring closet, Catalyst compact switches enable IP connectivity for devices such as IP phones, wireless access points, surveillance cameras, PCs, and video endpoints.
With their quiet, fanless design and compact footprint, these switches offer flexible mounting options and open up a variety of network design and connectivity options. Use them in offices, classrooms, hotels, retail stores, and other enterprise and branch locations. The setup allows for shorter cable runs from the compact switches, allowing for flexibility in space redesign and growth as the devices join the network - this eliminating the need for expensive and inflexible cabling infrastructure.
  • ETHERNET PORT CONFIGURATION
    8 10/100/1000 Gigabit Ethernet ports; 8 PoE+ output ports; two 1 G SFP uplinks; two 1 G copper uplinks
  • FANLESS DESIGN
    Silent operation
  • INCLUDED SOFTWARE
    Ships with LAN Base version of Cisco IOS Software
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 2960CX-8PC-L - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x SFP + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
124 W
Performance
Forwarding performance: 12 Gbps ¦ Forwarding performance (64-byte packet size): 17.9 Mpps
Virtual interfaces (VLANs): 255
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
BOOTP support, ARP support, VLAN support, Syslog support, DiffServ support, IPv6 support, STP support, DHCP snooping, PAgP support, ACL support, QoS, fanless, SRR, MAC Address Notification, RSPAN, Energy Efficient Ethernet, MVR, CoS, WTD
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3az
26.9 cm x 23.8 cm x 4.44 cm
2.27 kg
Enclosure Type
Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
124 W
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, system, link/activity
8 x 1000Base-T RJ-45 PoE+ - 30 W ¦ 1 x console RJ-45 ¦ 1 x mini-USB Type B management ¦ 1 x USB Type A ¦ 2 x 1000Base-TX RJ-45 uplink ¦ 2 x SFP uplink
Internal power supply
Power Provided
300 watt
24.5 watt
80 PLUS Certification
80 PLUS Silver
MTBF
569,530 hours
GOST, CISPR 24, EN55022, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ANATEL, GB 4943, KCC Class A, IEC 60825, KN22, KN24, VCCI V-3/2007.04 Class A, AS/NZS CISPR22:2004 Class A, CAN/CSA-C22.2 No. 60950-1
Software Included
Cisco IOS LAN Base
26.9 cm
23.8 cm
4.44 cm
2.27 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day ¦ Technical support - consulting - 90 days
-5 °C
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
BMXP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
BMXP C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
BMXP Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.70
BMXP Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
BMXP Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £19.94
Ports: 8
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £500 - £750
