The Cisco Catalyst Compact Switches easily expand your Catalyst switching infrastructure outside the wiring closet to enable workspaces, extend wireless LANs, and connect PoE devices. These fan-less, small form-factor switches are ideal for space-constrained deployments where multiple cable runs would be challenging.
The Cisco Catalyst 2960-CX compact switches help optimize network deployments. These Gigabit Ethernet (GbE) managed switches are ideal for high-speed data connectivity, Wi-Fi backhaul, and Power over Ethernet (PoE) connectivity in places where space is at a premium. With a single copper or fiber cable from the wiring closet, Catalyst compact switches enable IP connectivity for devices such as IP phones, wireless access points, surveillance cameras, PCs, and video endpoints.
With their quiet, fanless design and compact footprint, these switches offer flexible mounting options and open up a variety of network design and connectivity options. Use them in offices, classrooms, hotels, retail stores, and other enterprise and branch locations. The setup allows for shorter cable runs from the compact switches, allowing for flexibility in space redesign and growth as the devices join the network - this eliminating the need for expensive and inflexible cabling infrastructure.
ETHERNET PORT CONFIGURATION
8 10/100/1000 Gigabit Ethernet ports; 8 PoE+ output ports; two 1 G SFP uplinks; two 1 G copper uplinks -
FANLESS DESIGN
Silent operation -
INCLUDED SOFTWARE
Ships with LAN Base version of Cisco IOS Software -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 2960CX-8PC-L - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+) + 2 x SFP + 2 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 124 W
- Performance
- Forwarding performance: 12 Gbps , Forwarding performance (64-byte packet size): 17.9 Mpps
- Capacity
- Virtual interfaces (VLANs): 255
- Jumbo Frame Support
- 9018 bytes
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
- BOOTP support, ARP support, VLAN support, Syslog support, DiffServ support, IPv6 support, STP support, DHCP snooping, PAgP support, ACL support, QoS, fanless, SRR, MAC Address Notification, RSPAN, Energy Efficient Ethernet, MVR, CoS, WTD
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 26.9 cm x 23.8 cm x 4.44 cm
- 2.27 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 124 W
- Performance
- Capacity
- 9018 bytes
- Routing Protocol
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Port status, system, link/activity
- 8 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x console RJ-45 , 1 x mini-USB Type B management , 1 x USB Type A , 2 x 1000Base-TX RJ-45 uplink , 2 x SFP uplink
- Power Device
- Internal power supply
- Power Provided
- 300 Watt
- Voltage Required
- 24.5 Watt
- 80 PLUS Certification
- 80 PLUS Silver
- MTBF
- 569,530 hours
- GOST, CISPR 24, EN55022, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ANATEL, GB 4943, KCC Class A, IEC 60825, KN22, KN24, VCCI V-3/2007.04 Class A, AS/NZS CISPR22:2004 Class A, CAN/CSA-C22.2 No. 60950-1
- Software Included
- Cisco IOS LAN Base
- 26.9 cm
- 23.8 cm
- 4.44 cm
- 2.27 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
- -5 °C
- 45 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.25 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.00 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £80.90 |
Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.89 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £21.73 |
