The Cisco Catalyst 2960-C series compact switch is small form-factor Gigabit Ethernet and Fast Ethernet switches designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, branch office, classroom, cruise ship, and other wiring-constrained environments.
Cisco borderless networks and access switching
Borderless networks, a Cisco next-generation architecture, deliver the workspace experience, connecting anyone, anywhere, using any device, to any resource - securely, reliably, transparently. The Cisco borderless networks architecture addresses primary IT and business challenges to help create a truly borderless experience by bringing interactions closer to the employee and customer. -
Good for business, better for environment
Together, Cisco EnergyWise technology and Cisco Catalyst compact switches enable greenhouse gas (GhG) emissions reduction, increased energy cost savings, and sustainable business behavior. -
Cisco operational excellence: reducing operating costs
Cisco Catalyst 2960-C series compact switche makes deployment easy: reduce switch installation, configuration, troubleshooting time, and operational costs.
- Cisco Catalyst Compact 2960C-12PC-L - switch - 12 ports - Managed - rack-mountable
- Switch - 12 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 12 x 10/100 (PoE) + 2 x shared Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Forwarding performance: 10 Gbps
- Capacity
- Virtual interfaces (VLANs): 255
- Jumbo Frame Support
- 9018 bytes
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- DHCP support, PoE, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DAI, STP Root Guard, UDLD, fanless, DHCP relay, LACP, RSPAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 26.9 cm x 23.8 cm x 4.4 cm
- 1.86 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- Performance
- Capacity
- 9018 bytes
- Routing Protocol
- RIP-1, RIP-2
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 64 MB
- Status Indicators
- Port status, system, link/activity
- 2 x 1000Base-T RJ-45 , 12 x 100Base-TX RJ-45 PoE , 1 x console - mini-USB Type B management , 1 x serial (RS-232) RJ-45 management , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
- Software Included
- Cisco IOS LAN Base
- 26.9 cm
- 23.8 cm
- 4.4 cm
- 1.86 kg
- Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
- -5 °C
- 40 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
