Cisco Catalyst 2960-Plus 48PST-L Switch 48 ports Managed Rack-Mountable
Quicklinx: BJ0KWS00 Mfr#: WS-C2960+48PST-L
The Cisco Catalyst 2960-Plus series switch is a fixed-configuration Fast Ethernet switch that provides enterprise-class Layer 2 switching for branch offices, conventional workspaces, and infrastructure applications.
  • Enterprise-class quality of service
    The Cisco 2960-Plus series switch offers intelligent traffic management that keeps everything flowing smoothly. Flexible mechanisms for marking, classification, and scheduling deliver superior performance for data, voice, and video traffic, all at wire speed.
  • Cisco EnergyWise
    Cisco EnergyWise empowers IT teams to measure and manage the power consumed by devices connected to the network, providing measurable energy savings and reduced greenhouse gas emissions. EnergyWise policies can be used to control the power consumed by PoE-powered endpoints, desktop and data-center IT equipment, and a wide range of building infrastructure.
  • Power over Ethernet
    Cisco Catalyst 2960-Plus switch supports IEEE 802.3af Power over Ethernet (PoE) to deliver lower total cost of ownership for deployments that incorporate Cisco IP phones, Cisco Aironet wireless access points, or other standards-compliant PoE end devices. PoE removes the need to supply wall power to PoE-enabled devices and eliminates the cost of adding electrical cabling and circuits that would otherwise be necessary in IP phone and WLAN deployments.
  • Network management
    The Cisco Catalyst 2960-Plus series switch offers a superior CLI for detailed configuration and administration. 2960-Plus switch is also supported in the full range of Cisco network management solutions.
Cisco Catalyst 2960-Plus 48PST-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE) + 2 x Gigabit SFP + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
370 W
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 13.1 Mpps
Active VLANs: 255
Jumbo Frame Support
9018 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP
Layer 2 switching, auto-sensing per device, dynamic IP address assignment, DHCP support, PoE, auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, QoS, LACP, Port Security, MAC Address Notification, RSPAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
45 cm x 33.2 cm x 4.4 cm
5.4 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
370 W
Performance
Active VLANs: 255
Jumbo Frame Support
9018 bytes
Authentication Method
RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
24 x 100Base-TX RJ-45 PoE - 15.4 W , 2 x 1000Base-T RJ-45 , 2 x , 24 x 100Base-TX RJ-45
Internal power supply
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
FCC Class A certified, CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN22, KN24, EN 300 386
Software Included
Cisco LAN Base software
45 cm
33.2 cm
4.4 cm
5.4 kg
Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
BJ0K Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £34.99
BJ0K Cisco AC Power Cord In Stock £40.59
