Cisco Catalyst 2960 8-port Managed Switch
Quicklinx: DY37WS00 Mfr#: WS-C2960CX-8TC-L
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
£743.47 ex VAT
£892.16 inc VAT
The Cisco Catalyst 2960-CX Series Compact Switch help optimize network deployments. These Gigabit Ethernet (GbE) managed switches are ideal for high-speed data connectivity, Wi-Fi backhaul in places where space is at a premium. With a single copper or fiber cable from the wiring closet, Catalyst compact switches enable IP connectivity for devices such as IP phones, wireless access points, surveillance cameras, PCs, and video endpoints.
  • ETHERNET PORT CONFIGURATION
    8 10/100/1000 Gigabit Ethernet ports; two 1 G SFP uplinks; two 1 G copper uplinks
  • POWER CONSUMPTION
    18.8W at 100% throughput
  • FANLESS DESIGN
    Silent operation
  • INCLUDED SOFTWARE
    Ships with LAN Base version of Cisco IOS Software
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 2960CX-8TC-L - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x SFP + 2 x 10/100/1000 (uplink)
Performance
Forwarding performance: 12 Gbps ¦ Forwarding performance (64-byte packet size): 17.9 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
BOOTP support, ARP support, VLAN support, Syslog support, DiffServ support, IPv6 support, STP support, DHCP snooping, PAgP support, ACL support, QoS, fanless, SRR, MAC Address Notification, RSPAN, Energy Efficient Ethernet, MVR, CoS, WTD
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3az
26.9 cm x 21.3 cm x 4.44 cm
1.72 kg
Enclosure Type
Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, port transmission speed, port duplex mode, system, link/activity
8 x 1000Base-T RJ-45 ¦ 1 x console RJ-45 ¦ 1 x mini-USB Type B management ¦ 1 x USB Type A ¦ 2 x 1000Base-T RJ-45 uplink ¦ 2 x SFP uplink
Internal power supply
Power Provided
300 watt
16.7 watt
80 PLUS Certification
80 PLUS Silver
MTBF
756,260 hours
GOST, CISPR 24, EN55022, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ANATEL, GB 4943, KCC Class A, IEC 60825, KN22, KN24, VCCI V-3/2007.04 Class A, AS/NZS CISPR22:2004 Class A, CAN/CSA-C22.2 No. 60950-1
Software Included
Cisco IOS LAN Base
26.9 cm
21.3 cm
4.44 cm
1.72 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day ¦ Technical support - consulting - 90 days
-5 °C
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
DY37 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.70
DY37 Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
DY37 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £19.94
Ports: 8
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £500 - £750
