Cisco CATALYST 2960 48 10/100 POE + 1000BT +2 SFP LAN
Quicklinx: 695RWS00 Mfr#: WS-C2960-48PSTS
Cisco Catalyst 2960 series switches are fixed-configuration, standalone switches that provide desktop Fast Ethernet connectivity for entry-level wiring closet and small branch-office networks. These switches simplify the migration from non-intelligent hubs and unmanaged switches to a fully scalable managed network.
Cisco Catalyst 2960 series switches have lower cost of ownership with features such as intelligent switch configuration using Auto Smart Ports, installation with Auto Install and enhanced troubleshooting to facilitate ease of use. Comprehensive management tools such as Cisco Network Assistant provide ongoing management and monitoring of switches.
Services integrating voice, video, and wireless applications are possible using the Cisco Catalyst 2960 series LAN Lite Switches. Power over Ethernet (POE) and quality of service (QoS) provide comprehensive service delivery for entry-level customers.
Security capabilities that are pervasive in the network are critical for secure operations, and end-to-end security is obtained using the Cisco Catalyst 2960 series switches with LAN Lite software. An array of Cisco security solutions is available, including Cisco Clean Access NAC-based solutions.
Overall, the functionality available in Cisco Catalyst 2960 series switches with LAN Lite software provides peace of mind when dealing with today's network operations and lowers cost of ownership for customers.
  • Easy deployment and network management
    The Cisco Catalyst 2960 LAN Lite Series offers several ease of use features, which enable fast and easy configuration and installation of the switches into the network. Lowering the total cost of ownership and simplifying network operation are primary reasons for using the Cisco Catalyst 2960 switches.
  • Intelligent Power over Ethernet (PoE) management
    The Cisco Catalyst 2960 LAN Lite series can provide a lower total cost of ownership (TCO) for deployments that incorporate Cisco IP phones, Cisco Aironet wireless LAN (WLAN) access points, or any IEEE 802.3af-compliant end device. PoE eliminates the need for wall power outlets for each PoE-enabled device and significantly reduces the cost for additional electrical cabling that would otherwise be necessary in IP phone and WLAN deployments. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960 LAN Lite 48-port PoE configurations can deliver the necessary power to support 48 ports at 7.7W.
  • Security
    The Cisco Catalyst 2960 LAN Lite Switches support security features that can help your business protect important information, keep unauthorized people off the network, guard privacy, and maintain uninterrupted operation. The Cisco Identity-Based Networking Services (IBNS) solution provides authentication, access control, and security policy administration to secure network connectivity and resources. Cisco IBNS in the Cisco Catalyst 2960 LAN Lite Series prevents unauthorized access and helps ensure that users get only their designated privileges.
Cisco Catalyst 2960-48PST-S - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE) + 2 x SFP + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 13.3 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Layer 2 switching, auto-sensing per device, DHCP support, PoE, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DTP support, PAgP support, QoS, LACP, Port Security, MAC Address Notification
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44.5 cm x 33.1 cm x 4.4 cm
5.45 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
64 MB
Flash Memory
32 MB
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
48 x 100Base-TX RJ-45 PoE , 2 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 2 x SFP (mini-GBIC)
Internal power supply
52 watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
181,979 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Lite
44.5 cm
33.1 cm
4.4 cm
5.45 kg
Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
695R Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £117.18
695R Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £34.66
695R Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £79.20
695R Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £78.13
