Cisco Catalyst 2960 Series Intelligent Ethernet Switches enable entry-level enterprise, medium-sized, and branch office networks to provide enhanced LAN services. This family of fixed-configuration, standalone devices provide desktop 10/100 Fast Ethernet and 10/100/1000 Gigabit Ethernet connectivity.
- Cisco Catalyst 2960-24-S - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100
- Performance
- Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 3.6 Mpps
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
- Layer 2 switching, auto-sensing per device, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DTP support, PAgP support, QoS, LACP, Port Security, MAC Address Notification
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44.5 cm x 23.6 cm x 4.4 cm
- 3.65 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100
- Performance
- 8K entries
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 64 MB
- Flash Memory
- 32 MB Flash
- Status Indicators
- Port status, port transmission speed, port duplex mode, power, system, link/activity
- 24 x 100Base-TX RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 22 watt
- Redundant Power System (RPS) connector
- Rack Mounting Kit
- Optional
- MTBF
- 429,847 hours
- TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
- Software Included
- Cisco IOS LAN Lite
- 44.5 cm
- 23.6 cm
- 4.4 cm
- 3.65 kg
- Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
- -5 °C
- 40 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £35.26 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £77.33 |
