Cisco C819 M2M Hardened Secure Router
Quicklinx: CBSNWS00 Mfr#: C819H-K9
Cisco 890 series integrated services routers combine Internet access, comprehensive security, and wireless services in a single, secure device that is easy to deploy and manage. The best-in-class Cisco 890 series architecture has been specifically designed to deliver high performance with concurrent services, business continuity, and investment protection for enterprise small branch offices and service provider managed services applications.
Cisco 890 series integrated services routers are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They are designed to deliver secure broadband, Metro Ethernet, wireless LAN (WLAN) connectivity, and business continuity. The routers also come with powerful management tools, such as the web-based Cisco configuration professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
  • Single platform for multiple applications
    This single architecture is uniquely designed for deployments in multiple remote applications such as ATM machines, kiosks, small branch offices, remote teleworker sites, gas stations, telemetry, etc. and across all industries. Hardened models extend the ISR footprint into deployments wherein the router is exposed to extreme environmental conditions such as heat dissipation, exposure to extreme temperatures, dust, splash water, shock and vibration.
  • Lightweight, compact size with low power consumption
    Can be deployed in many different environments where space, heat dissipation, and low power consumption are critical factors.
  • Increased performance to run concurrent services
    Performance allows customers to take advantage of broadband network speeds while running secure, concurrent data, voice, video, and wireless services.
  • Enhanced security
    An integrated stateful and application inspection firewall provides network perimeter security and high-speed IP Security (IPsec); 3DES and AES encryption offer data privacy over the Internet. Intrusion prevention enforces security policies in a larger enterprise or service provider network. Content filtering offers category-based URL classification and blocking, thus providing increased productivity and better use of company resources.
  • Four-port 10/100-Mbps managed switch
    It allows for multiple Ethernet device connectivity in a small office or other remote location with the ability to designate a port as the network edge. VLANs allow for secure segmentation of network resources. Multiple LAN and WAN devices can be connected to standard 10/100/Ethernet or serial interfaces.
  • Dual subscriber-identity-module (SIM) support
    Hardware readiness for Dual SIM provides for high reliability and cellular multi-homing support for HSPA-based networks.
  • Advanced security features
    Authorization and authentication determines which individuals and devices have access to the network. Firewall protection provides perimeter security when using public networks. 3DES and AES encryption provides for highly secure VPNs when transmitting and receiving data over public networks.
  • QoS features
    It provides traffic precedence to delay-sensitive or prioritized applications. Facilitates low-latency routing of delay-sensitive applications such as streaming video.
  • IP multicast
    It allows efficient broadcast of data or video for increased situational awareness, multiuser communications, or surveillance applications.
Cisco 819 Secure Hardened Router with Smart Serial - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet
IPSec VPN tunnels: 20
Network / Transport Protocol
L2TP, IPSec, DHCP, L2TPv3, DDNS
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, NHRP, GRE, policy-based routing (PBR), WCCP, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
Telnet, SNMP 3, HTTP, SSH, CLI
Firewall protection, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, content filtering, DiffServ support, MAC address filtering, IPv6 support, Intrusion Prevention System (IPS), firmware upgradable, Low-latency queuing (LLQ), Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic Multipoint VPN (DMVPN), RADIUS support, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), DNS proxy, DHCP relay, DHCP client
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
19.6 cm x 20.6 cm x 4.4 cm
1.5 kg
1-year warranty
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, PKI, 128-bit AES, 192-bit AES, 256-bit AES
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, FCC CFR47 Part 15, UL 60950-1 Second Edition, MIL-STD 810G, BSMI CNS 13438, EN 301 908, VCCI V-3, IP41, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, SAE J 1455, EN 301 489-7, EN 301 489-1, EN 300 386, EN 301 489-24, EN 301 511
RAM
1 GB (installed) / 1 GB (max)
Flash Memory
Status Indicators
System, active
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x RJ-45 , USB: 1 x mini-USB Type A , Serial: 1 x 26 pin Smart Serial
External power adapter
20 Watt
1 x network cable - 1.83 m
MTBF
1,000,000 hours
OS Provided
Cisco IOS Advanced IP services
19.6 cm
20.6 cm
4.4 cm
1.5 kg
Limited warranty - 1 year
-25 °C
60 °C
